alot of smoke out of 95 volvo 850 turbo
turbo is perfect i did the revuild perfectly iv done about 100 turbos but i learned last nite that its white smoke i let it run for about 45 min it never overheated but i put my hand against exhaust and pull my hand away and it wet with moisture so and water if filling up reservoir like combustion is getting inside water is it my head or head gasket no water leaking on ground
when i crank it up its blowing back into coolant reserviour the water in reservior has qlot of black particles in it.i read tgat tge head gaskets on tgem can leak water into combustion chamber it has so much smoke coming from it i held a sheet of paper against exhaust and it was soaking wet no with moisture it runs rough like water is mixing with fuel it set up about a yr has smoked since 5 yrs ago replaced pcv system a few yrs ago and so much smoke its not drivable .what u think could water get in gas tank usually?
Smoking like this?
This was the turbo, lost the thrust bearing.
You should pick up a block tester kit. They are cheap and it will answer your question (although I think we all know what it is).
http://www.autozone.com/loan-a-tools/block-tester
schwing
10-01-2008 08:36 AM
