Broken vacuum tube near MAF
I just found a broken vacuum tube between MAF and air intake hose. I will definitely replace this, but where should I connect it to? The other end may pop off, as I did not find it.
To O2 sensor? my best guess...
What is that for? I did not get any bad drive without this connection.
Last weekend I took off my air intake hose to clean it out. After reassembling I forgot to reconnect this hose and noticed my car idled rougher than usual. After reconnecting it was back to normal.
Maybe after being disconnected so long, you are used to the rough idling.
For me it was not extremely rough but felt like the engine was skipping a beat every couple seconds (very slight loss of power for an instant).
Maybe this will help clarify...
It connects under the air intake hose.
The air intake hose is the large black hose that runs from the airbox to the turbo behind the engine. It has an accordian-like appearance.
The nipple you are looking for should be on the part of the air intake hose very close to the airbox. Just reach your hand under and feel for a nipple.
the airbox thermostat is in the lower part of the airbox.if you have ever taken the airbox out you will notice the flaps that open and close to adjust cold or hot air to flow depending on the engine temp.if you are bored one day you might want to take out the thermostat and test to see if it is still working.or you can rig it to stay open to the cold intake all the time for better performance
bcolins
2001-2013 model year V70
Oct 28, 2013 10:55 AM
