A/C compressor?
Old Aug 27, 2010 | 07:33 PM
garlendrix's Avatar
Default A/C compressor?
So when I turn the air on it blows hot air. I got out to listen to the compressor and it turns off and on quite frequently. Does this sound like a bad compressor?
Old Aug 27, 2010 | 10:32 PM
Sounds like low freon. you should check the pressure on the system. if it's low, have it serviced with freon with dye in it. then check for leaks 2 weeks later. replace the leaking parts.
Old Aug 28, 2010 | 09:41 AM
SVTfocusO3's Avatar
If you do not see any obvious leaks, your evaporator is more than likely the culprit. You may have to pull the passenger knee bolster down, and panels, and remove the heat sink to check it.
Old Aug 28, 2010 | 12:46 PM
garlendrix's Avatar
How much could i expect to pay for the frion dye test? I have a parts 850 with all the a/c stuff working, should I just replace the stuff? If so, what stuff would be most benificial to replace?
skamil
Sep 2, 2021 08:44 AM
sghokie
Jul 25, 2011 05:00 AM
camera cart
Jun 3, 2005 03:45 PM
etype38
May 4, 2005 07:08 PM
RonNaismith
Feb 28, 2005 07:24 PM
