clunking noise from the drivers side
Old Apr 16, 2011 | 04:19 PM
taf1961's Avatar
Default clunking noise from the drivers side
I have a 1995 850 GLT sedan, my driveway is kinda rough and I hear a clunking noise from the drivers side. What should I look for?
Old Apr 16, 2011 | 05:32 PM
MattyXXL's Avatar
Tons of posts on this already... Here are some I pulled by a quick search.. But sounds like a spring seat to me
https://volvoforums.com/forum/volvo-...er-side-52557/
https://volvoforums.com/forum/volvo-...g-sound-52011/
https://volvoforums.com/forum/volvo-...nocking-49241/
Old Apr 16, 2011 | 05:57 PM
redchicken's Avatar
Most likely the sway bar link. Take off the tire on the side of clunking, stick a crowbar between the sway bar and the frame, and push down on the sway bar. If there is movement where the vertical sway bar link connects to the sway bar you need to replace the sway bar link. Easiest repair you could ever have!
Old Apr 16, 2011 | 06:31 PM
taf1961's Avatar
Thanks, Im new at the forum and Volvo 850. Just bought this car and i am working out some minor kinks.
Old Apr 16, 2011 | 06:38 PM
MattyXXL's Avatar
Not to say red chicken is wrong, you may have an issue with that also but 100% of 850's as well as other models have the same spring seat issue every now and then..
Ive done mine 3 times in 16 years
Old Apr 17, 2011 | 09:21 AM
brianb's Avatar
I actually have what can be best described as a plastic-y clunk sound. Mine appears to be the spring seat. What I did to test mine was:
- pop open the hood
- push down on the car
- if you see movement on the strut cap, the spring seat is your likely
culprit
hayn5-0
Jun 29, 2011 07:14 PM
ToledoVolvo01
Apr 30, 2010 09:34 PM
redvv07
Jul 30, 2009 11:06 PM
robber
Dec 16, 2007 11:11 AM
m1964
Feb 3, 2006 12:32 AM
