Coolant Temp. Sensor
Old Jul 7, 2014 | 01:21 PM
argus's Avatar
Default Coolant Temp. Sensor
Hi I have a 850 and after warming up it won't re-start. Can someone tell me what the temp. sensor should read when cold and then when hot or the resistance ohm's when hot and cold .... thanks.
Old Jul 7, 2014 | 02:50 PM
boxpin's Avatar
Dont bother, replace it.
Old Jul 7, 2014 | 04:01 PM
While you are at it, don't get a cheap after market one, get a real Volvo one. Many suppliers sell them.
If you have NOT replace the thermostat in a while, replace it as well.
Old Jul 7, 2014 | 04:40 PM
argus's Avatar
I would replace it if I knew that was my problem don't want to start replacing parts for no reason, this is why I wanted the proper readings to do a test first.
Old Jul 7, 2014 | 06:12 PM
Google will be your friend.
Old Jul 7, 2014 | 10:28 PM
gdog's Avatar
Best way to ck it is with OBD2 scanner; should read ambient on cold engine and right around 200 F at operating temp.
Does your temp gauge get to 3 o'clock within 5-10 minutes of running?
Guys are saying just to replace them because both are common failure points.
FYI: via google; see post #10
https://volvoforums.com/forum/volvo-...sor-iat-68116/
Old Jul 18, 2014 | 12:10 PM
argus's Avatar
Default Still no work
Hi .... Anymore suggestions now that I replaced the Temp. Sensor and the car still won't re-start after it gets hot, after cool down no problem. I don't like guessing and replacing parts for no reason, this is why I try to do what I can my self the "mechanic" will just say well it was getting bad anyway. Well that could be but still no need to replace something it doesn't need at the time. Any help would be appreciated ....
Old Jul 20, 2014 | 10:11 PM
maccampbells's Avatar
I had the same problem as you; hard starting when cold, misfire when warm. After a lot of diagnosis (and the resources here, esp. Robert) I ended up removing the distributor cap getting ready to replace it. There was oil in the cap. I cleaned out the cap and rotor with break cleaner and polished up the contacts. Voila, problem solved. Still, gotta keep that oil from getting in there now.
blackbrick
May 7, 2011 01:46 PM
cisopen
Sep 20, 2010 05:25 PM
angel308
Jan 23, 2008 06:36 AM
vcolper
Nov 1, 2006 10:20 PM
