Engine Mount Saga ... Help!! lol
Old Mar 19, 2011 | 08:21 PM
calebfrida's Avatar
Default Engine Mount Saga ... Help!! lol
I'm doing some R&R on my wife's Non-Turbo 1997 Volvo 850. The project this weekend is fixing all the engine mounts.
I changed the upper torque mount (PITA!! lol) and the mount in the passenger wheel well un-eventfully once I finally got the new upper torque mount pressed into the arm.
Here's my problem that's driving me nuts. I jacked up the engine and changed the front hydraulic mount and lightly tightened the bolts. So far everything seems fine so I moved onto the rear mount and had a little more trouble with clearance. I jacked up the engine about 1/8th of an inch too high and heard a pop. I got the rear mount changed out and everything put back in place, glad to be finished, and decided to go for a quick test drive.
I started the car and tried to put it in gear and it was hard to move it from Park to Reverse. I freaked out that I screwed something up, so I pulled the airbox and the battery then realized that the PNP switch was slightly high and rubbing on the bottom of the battery tray and that the gear selector would move easily back and forth with that out. Now that I'm looking at it, the motor seems to be higher on the drivers side than the passenger side. And actually that would make sense why the PNP switch is rubbing and giving me some issues.
I'm going to take it apart again tomorrow afternoon and see if anything jumps out at me when I'm fresh and not frustrated with it.
Has anybody had any problems like this??? It's like the the mounts are too large and raising the engine too much. They are URO mounts from FCP Groton.
Old Mar 19, 2011 | 09:17 PM
Make sure the pins on the top of the mounts went where they should be.
Also make sure you did not pop the inner C/V joint out of the cup at the transmission.
Easiest way to check is jack the entire front end up and try to rotate the wheels by hand. Usually if the inner joint pops out when you rotate the wheel it will pop back in.
Old Mar 19, 2011 | 09:53 PM
calebfrida's Avatar
AHhhh, That's it!! Thanks Tech!!! I was going nuts because I couldn't find anything out of place with the mounts.
I jacked it back up and started turning the drivers wheel and the engine would slowly rise up and down. After a couple rotations there was a loud pop and everything settle back into place. Thanks your a life saver!! I owe you a pack of beer next time your in SC!
Old Mar 20, 2011 | 07:35 AM
Glad that was all it was.
Bobby Grady
Jan 6, 2013 04:00 PM
mrlowkey
Jul 27, 2010 09:39 PM
Flick
Jul 11, 2010 08:18 AM
nashvillecritter
Mar 20, 2010 06:36 AM
JimKW
Jun 29, 2005 03:15 AM
