Engine swap! what to do While I am there?
Old Oct 18, 2010 | 01:00 PM
grigalid's Avatar
Default Engine swap! what to do While I am there?
I am purchasing a used motor and will be performing a swap on my '96 850 2.4L non-turbo. The compression/rings are shot on it, among other things.
What should I consider doing while I have the motor out?
-timing belt
-belts, of course
-PCV system (I just installed a new one on my dying car, is there a way to clean it up rather then buying a new one?)
-plugs, dist, wires
-motor mounts depending on what they look like
any other ideas?
Thanks for the help
Old Oct 18, 2010 | 05:55 PM
megail's Avatar
water pump for sure since it'll be a lot easier with it out.
i'd redo all the seals i could, including the rear main and cam seals.
Old Oct 18, 2010 | 07:40 PM
gilber33's Avatar
Everything. Hoses, RMS, cam seals, t-belt/waterpump, all engine/subframe mounts....everything.
Old Oct 18, 2010 | 08:08 PM
ibified's Avatar
Yeah, cam seals, front and rear main seal, water pump, timing belt, PCV system (better to replace than clean), t-stat, cap, rotor, plugs, plug wires....essentially everything you would do to a new car to get it to a solid stage zero.
lukaspanic
Mar 17, 2011 12:32 AM
donf
Oct 25, 2010 10:38 PM
vw_jason79
May 20, 2010 10:58 AM
