flashy rec & ac illuminations!
Old Feb 2, 2006 | 01:56 AM
Mass850's Avatar
Default flashy rec & ac illuminations!
My turn for this I guess !!
Anyway, since mine is a 95 wagon, am I right in thinking that standing huddled over the little boxs under the hood will result in me locating meaninful codes? And if so, where do I put the jumper and what do I press for climate control feedback? I assume I can get this on a 95?
I suspect 2 or 3 possibilities, feel free to tell me if they sound way off;
1. I recently replaced the blower motor, not the resistor.
2. My blend and response to different air direction is sluggish occasionallly.
3. My A/C is noisy when working, and doesn't appear to be low on freon.
Cheers,
Old Feb 2, 2006 | 08:59 AM
info2x's Avatar
Default RE: flashy rec & ac illuminations!
ORIGINAL: Mass850
95 was a split year. If you have a coin holder on your center console then you have OBDII for pulling codes, if you don't have the coin holder then you're right huddling over the little boxes underneath the hood will give you the codes you're looking for.
I believe the jumper is on the B box, but I'm not sure which one exactly. http://www.troublecodes.net/Volvo/ will show you how to access trouble codes.
I would think the code would have to do with reason #2. When my blower died I didn't get any codes and I had to replace both motor and resistor.
Old Feb 2, 2006 | 08:52 PM
Climate control is B1.
mrlament
Jan 12, 2008 09:05 PM
dnault
Nov 10, 2007 12:27 AM
megatrack
Sep 3, 2007 03:14 AM
Sweet T5R
May 14, 2007 07:15 AM
ludeless
Jan 11, 2006 11:20 PM
