Harsh bang when putting transmission in reverse.
Old Jan 27, 2012 | 03:43 PM
  #21
boxpin's Avatar
Blow the engine, replace the engine and transmission, no "bang".
Thats my story.
Originally Posted by slimflex2
what happened for you to blow your engine?so you mean you kept it like that till you changed it to a manual?nothing happened to it till you blew your engine?
I filled the coolant reservoir up and did not put the cap back on. Drove up into the mountains. The coolant level switch apparently was broken and did not warn me. Overheated the engine...really bad. Blew the head gasket, seriously warped the head. Had the car towed home where it sat for one week before I pulled the head to assess the damage. I waited to long and this was my demise.
So I bought a 95 T-5R and pulled the engine and trans out of it. I knew I had a problem with the reverse so I put the T-5R transmission in with the motor. Problem solved. Thats my story.
Old Jan 27, 2012 | 10:21 PM
  #22
ABVO850's Avatar
Same problem with me. Ill post if I get a resolution
Old Jan 27, 2012 | 11:17 PM
  #23
slimflex2's Avatar
thanks man, just let me know when you get yours fixed.
@ boxpin. the head was really blown. ouch. l dont know why alot of 850s have this problem.l had a 94 850 and it did the same thing till l got this 97 850. does the same thing. l think its something with 850s after the transmission goes over a certain miles.
Old Feb 1, 2012 | 06:32 AM
  #24
Tychondrias's Avatar
I had a similar "bang" in my 98 S70 just before the transmission went bad and needed a rebuild.
I also had bad axles and hub bearings, which could have been adding to the issue. I ordered a used transmission and had it installed, no more bang.
Old Feb 2, 2012 | 09:09 AM
  #25
slimflex2's Avatar
really,what could have been the cause of the hard bang? is there any solution you could give to me?thanks
Old Feb 2, 2012 | 09:08 PM
  #26
There are only so many things that can cause it. If you've checked the half shafts for play in the CV joints, the hub bearings, the struts and control arms, engine mounts, body mounts and brake calipers to the mounts for play ,,,,,, you have come down to the point of it being transmission internal.
Old Feb 2, 2012 | 10:02 PM
  #27
boxpin's Avatar
What I had was internal. I know there is a lot of talk about it being mounts, etc. I think when you have it you know thats not the case. Its a pretty abrupt slam. Best think you can do is flush the fluid.
Old Feb 2, 2012 | 11:18 PM
  #28
slimflex2's Avatar
l did flush the flood with mobil 1.but l will try and install a new mount and flush it again and see if that solves the problem.
Old Feb 3, 2012 | 06:41 AM
  #29
Default hope
How long has it been happening? When my transmission went bad, it was shortly after I heard the first bang. I got the bang when I would shift to reverse.
Old Feb 3, 2012 | 12:56 PM
  #30
slimflex2's Avatar
this has been going on for a while now. l made my mechanic take a look at it and when l put it to reverse the engine itself moves big time.u can clearly see it move like something is off the engine.he told me the engine mounts are going bad.l hope thats only thing making it bang like that.l will change the mounts and see what happens.if that doesnt solve the problem l will then have to live with it and save some money towards getting another car.not a volvo.lol
Old Feb 6, 2012 | 06:11 AM
  #31
Default good news
The good news for you is that if it was an internal transmission problem, it probably would have went by now and you'd be paying big money to have it fixed.
Funny you mention you won't buy another Volvo, I've always been told they are very reliable vehicles, and I'm sure they are... but I've had nothing but problems with my 98 S70. It has 150k miles on it, and every month it seems something else goes wrong, each time more expensive than the last.
Let me know if fixing the engine mounts solves your problem!
Old Feb 12, 2012 | 04:22 PM
  #32
trackstar's Avatar
Too funny, guys! My '94 Turbo wagon does exactly the same thing. When it is warm, and you put it in reverse. Bang! When tranny is cold, no bang. I thought my car was a one off. Been doing this since November now. I have a bunch of parts for the car which is sitting in garage waiting to go in (Bilstein HD's, Momo steering wheel and hub, IPD springs, 17" wheels and 215/45-17 tires, performance brake pads, Iquus boost gauge). Gonna hold off putting this stuff on for now, to see what you guys come up with for a fix. If auto transmission needs to be rebuilt, I will just go and buy another 850 Turbo or S70 Turbo. Then put on the awaiting goodies onto that car.
Old Feb 12, 2012 | 05:45 PM
  #33
slimflex2's Avatar
L changed my transmision mount and the bang reduced.it does not bang like it used to.now l removed my lower motor mount and its about 90 percent worn out.my motor moves too causing that big bang.l will replace the lower mount and let you guys know
netdvn
Jul 2, 2015 12:13 PM
vladimur1
Jul 1, 2012 11:38 PM
slimflex2
Jan 5, 2012 11:16 PM
desiaashik
Jun 9, 2009 10:51 AM
