My volvo acting strange, need som help
Old Feb 14, 2015 | 02:13 PM
Tommyaleks's Avatar
Default My volvo acting strange, need som help
Hi all. Like the headline say, My volvo acting strange. I have a Volvo 850 2.0 Automatic 1996. The problem is the trottle and engine.
When I driving the car is so slow when accelerating, it`s same as the brakes hangs on or something (the brake is ok). The trottle cable is also a little hard to push down. But sometimes the engine kicks to and the trottle cable is a little lighter to push down and the car flying away. it`s like the brakes let go. it goes a little time and then it goes back to normal again. If you can call it that.
I have a thought about the trottle cable but I think that is strange beacouse that has nothing to do with the accelerating of the engine and the slow motion. Bybe I`m wrong here, I don`t know.
I hope anyone here can help me with som answers to this problem.
Old Feb 14, 2015 | 05:33 PM
What year is your car? Is the CEL on?
Old Feb 14, 2015 | 07:47 PM
Tommyaleks's Avatar
it is a 1996 mod. I don`t quite understand what light you are talking about. I have no check engine light on my car. I have a engine electronic diagnosic error light and a Service reminder light, but anyway, non of them is on when the engine is running. I did a diagnostic test on the car and no error codes.
This is a Non turbo car.
Old Feb 14, 2015 | 09:30 PM
CEL=Check Engine Light. Have you inspected the throttle cable? Is it installed properly? When was the last time the car was tuned up?
Old Feb 15, 2015 | 06:55 AM
Tommyaleks's Avatar
I don`t have that CEL engine light on my car, instead I have the Y chaped light Engine electronic diagnostic light. But all of my warning ligt`s are off when the car is running and no error codes to read.
I did check the trottle cable as you sugested. I hade some WD40 on it and the trottle system too. but that did not work. it is the same as before.
Old Feb 15, 2015 | 08:12 AM
Tommy, you really have an issue with addressing 1/2 of my post. That can get frustrating to me, posting my suggestions and questions over and over again.
When is the last time the car had a tune up?
Old Feb 15, 2015 | 10:20 AM
Tommyaleks's Avatar
Ok sorry for my bad English. About the CEL light, it is off when the engine is running. no lights at all. and no error codes.
I have never tuned my car, I had my car for about 1 year.
Old Feb 15, 2015 | 12:49 PM
That might help.
Old Feb 16, 2015 | 05:54 AM
Tommyaleks's Avatar
After some examinations I found out that the switch for the winter mode was bad. When the winter mode kicks in the transmission starts in 3 gear and that causes the bad acceleration. I changed the bad switch and now it`s working normal again, all the time.
Thank you for your time to help me rspi.
Old Feb 16, 2015 | 07:49 AM
Glad you found the problem.
Old Feb 18, 2015 | 11:45 AM
Tommy,
Thanks for posting your solution to the problem! This always helps the next person in line...
Newport_j
Aug 9, 2011 09:16 PM
RaginRanger
Nov 21, 2009 07:53 PM
atexasex
May 28, 2008 04:13 PM
raghu9
Apr 1, 2008 03:37 PM
JustGotMineAndLoveIt
Nov 24, 2007 01:50 PM
