newly purchased 850 turbo questions?
Old Oct 21, 2008 | 09:24 PM
TurboGT's Avatar
Default newly purchased 850 turbo questions?
hello im new to the site and had a few questions about my 1996 volvo 850 turbo. I bought the car with a pulled head. He claimed the headgasket was bad but i looked it over and it seems to be normal wear nothing major or signs of leaking at all? i was wondering if it would be a really good idea to have the deck of the motor checked for straight ness. I am also looking for a new turbo cylinder head to put back on it bc the stock one he did not label the cam caps and i dont want to buy new cams and re hone the bores unless its more cost effective. since the head is off and i am new to the volvo community what maintience should be done or is good to get out of the way. Also where should i purchase new head bolts? Thanks for any help or information!
Old Oct 21, 2008 | 09:40 PM
TIPSP's Avatar
Got Boost?
Default RE: newly purchased 850 turbo questions?
Welcome.
IPD has the head bolts: http://www.ipdusa.com/Volvo-850/Engine/Engine-Mechanical/Engine-Fasteners/p-72-153-168-4463/
they are a good company to work with
VMS has Remanufactured Heads and bolts also, but I hear good and bad reviews, they might have gotten better:
http://www.volvomotorsports.com/catalog/index.php?cPath=26&osCsid=d2ae236bda73f0f117d8 09a39cc91958
You can also try:
http://www.fcpgroton.com/http://www.motors.ebay.com/http://www.europartsdirect.com/http://pelicanparts.com/http://www.vlvworld.com/indexframe.html
FCPgorton is a good company and so is PelicanParts
I would do a major tune up, like: plugs, wires, dist car, new fluids, All new gaskets...ect.
Good luck.
Old Oct 21, 2008 | 09:48 PM
TurboGT's Avatar
ORIGINAL: TIPSP
Welcome.
You can also try:
Good luck.
awesome info thanks i will be looking into it even more! does anyone ever sell used heads on this site 1100 is a little steep at the moment
Old Oct 21, 2008 | 09:59 PM
TIPSP's Avatar
Got Boost?
Head work usaually cost some $$$, but it will be worth it.
I am surethereare some headsout there. Look in the For Sale section of this forum.I am sure you could find one at a juck yard.
You could alsotry turbobricks or swedespeed.
Good Luck.
Old Oct 21, 2008 | 10:43 PM
TurboGT's Avatar
awesome ill check them out thank
Old Oct 22, 2008 | 07:55 AM
Im a little confused about a statement above.
Are you talking about the lifters?
Did he not bolt the cam cover back together?
Old Oct 22, 2008 | 08:46 AM
Psaboic's Avatar
As long as the head is off, I would go ahead and check the block deck for any damage. You could alos check to see the condition of the cylinder bores (taper, ridge, etc) but unless the engine has a TON of miles of was severely overheated, you should be ok!
Old Oct 22, 2008 | 09:44 AM
TurboGT's Avatar
ORIGINAL: tech
the cam caps that hold the cam in? they were taken off and not labeled?
Old Oct 22, 2008 | 09:45 AM
TurboGT's Avatar
ORIGINAL: Psaboic
car has original 119k miles and never overheated and also from the looks of it the stock gasket looked healthy
Old Oct 22, 2008 | 02:39 PM
ORIGINAL: TurboGT
ORIGINAL: tech
The cams are not held in by seperate caps. The entire cam cover holds the cams in.
SO there should be nothing wrong with putting it back together.
Old Oct 22, 2008 | 06:46 PM
Ozark Lee's Avatar
Check on eBay. I saw one today off of a '95 turbo which should be the same and I think it was at around $50.00 and it included the cams. I couldn't tell if had the lifters but I assume that it does.
...Lee
Old Oct 22, 2008 | 10:05 PM
TurboGT's Avatar
ORIGINAL: tech
ORIGINAL: TurboGT
ORIGINAL: tech
ok ill look at it again i never really looked at the head closly bc i assumed it was like any other ohc motor. well that might be good news after all. in any case the turbo is shot. there in and out play like crazy! so i need to hunt down a new turbo
Old Oct 22, 2008 | 10:06 PM
TurboGT's Avatar
ORIGINAL: Ozark Lee
...Lee
excellent i will look tonight.
missthe122
2001-2013 model year V70
Sep 1, 2013 09:34 PM
transman86
Jan 12, 2013 03:46 AM
samtheman77
May 20, 2009 08:14 PM
green850
Feb 25, 2008 03:53 PM
estrn_uro
Nov 6, 2007 09:44 PM
