Probably the funniest problem ever. Wipers Won't stop!
Old Dec 17, 2007 | 11:08 AM
Evo 850's Avatar
Default Probably the funniest problem ever. Wipers Won't stop!
If I try and use the windshield waster fluid motor to spray on the windsheild, the wiper blades immediately go into top speed and will NOT STOP no matter what I do with the control lever. I turn the car off, and back on, and they are going max speed, as are the headlight blades. I almost fell over laughing..
I pulled the fuse, put it back in, turned the car on, still GOES!. I pulled the fuse off, drove around a little bit, put the fuse back in, and they stopped. lollll
I can use the wiper blades, just not the washer motor. What gives? I should get a video...
Old Dec 17, 2007 | 03:24 PM
JPN's Avatar
JPN
Default RE: Probably the funniest problem ever. Wipers Won't stop!
One alternative to this problem is to make the car a "Rainy Day Only" vehicle.
.....[8D]
Will look up the manual after work to see what I come up with. Could be stuck-closed relay if the wiper/washer uses a relay.
JPN
Old Dec 17, 2007 | 10:54 PM
240maybe's Avatar
that is a very funny scenario. :0 good luck with the fix!
Old Dec 18, 2007 | 10:40 AM
92Typhoon's Avatar
ORIGINAL: JPN
.....[8D]
JPN
I was going to mention relay too, but couldn't remember if the 850's used a wiper relay. I didn't think there was enough speed variation on the wipers to warrant a relay, but then again, it is a European auto and they love their electronic components.
Old Dec 18, 2007 | 08:21 PM
My guess is the wiper motor.
The park position part of it is bad.
Old Dec 18, 2007 | 09:09 PM
JPN's Avatar
JPN
Follow Tech's advice first.
JPN
Old Mar 13, 2010 | 02:10 PM
850forum's Avatar
I discovered an unplugged connection behind the driver's headlamp & plugged it in. The next time I used the windshield washer, the drivers' headlight wiper would not stop running & also it sounded like it was trying to keep pumping fluid.
[ EDIT: The motor is running, but the wiper is not moving. When I touch the motor, it "wobbles" and I get the impression that a support is broken. ]
Is there a way to repair the motor, or at least inspect it to see if something is stuck.
How do you remove the motor?
Some one posted this diagram of the front headlamp washer hose routing & part numbers:
http://img8.imageshack.us/my.php?ima...hersystem2.jpg
Also neither headlamp wiper actually squirts fluid. The rear window doesn't either ( 1995 850 Turbo wagon).
How do I remove the washer fluid reservoir so I can inspect everything?
Old Sep 18, 2012 | 08:58 AM
Christie Klein Strain's Avatar
2007 Volvo my wipers will not shut off?
Old Sep 18, 2012 | 12:58 PM
Should have a relay somewhere. I'd start there.
Old Sep 18, 2012 | 08:16 PM
boxpin's Avatar
I provided the music....
Old Sep 20, 2012 | 08:47 PM
1995Volvo850's Avatar
Top gear UK had a similar thing go wrong with some other Volvo wagon they were using!
Old Jan 14, 2017 | 11:13 AM
Clive Fox's Avatar
Just had this problem with my R reg V70. Disconnecting the headlamp wipers (simple push fit brown plastic connectors lying on top of the headlamp housings) resolved the problem. I'll just live without the headlamp wipers.
dmg4
Jul 13, 2013 06:55 PM
gthornton
Dec 5, 2012 10:56 AM
jigen3
Nov 27, 2012 03:20 AM
trev0006
Nov 3, 2012 12:20 PM
JimKW
Forum Issues
May 27, 2008 09:16 PM
