Service engine light not resetting...
Old May 31, 2011 | 07:35 PM
maddhatter's Avatar
Default Service engine light not resetting...
I had a check engine light and a service engine light on my girlfriends car that I wanted to get rid of. I easily removed the check engine light, but when I went to remove the service engine light, I could not get it into the modify zone. When I would connect the #7 connector and press the button 4 times, I would get a quick flash after 5 seconds instead of a constant light. If I continued on, nothing would happen. Is there some reason it won't go into the correct mode for me to remove the service light? Car is a 95 850. Thanks in advance.
Old May 31, 2011 | 09:02 PM
91shelby's Avatar
you have to repeat all the codes at least once, then you have to hold the button for 8-10 seconds wait for the light to go solid then push and hold another 8-10seconds and it should go off and you then should be able to read the code again and it should be 111
Old May 31, 2011 | 09:15 PM
maddhatter's Avatar
No, the check engine light was no problem to turn off as I went through all the codes once and then held the button to get to the 1-1-1 flash to remove it. It's the service engine soon light that I can't get off as it is supposed to be to push the button 4 times to get into the system so you can then delete the light. When I push the button 4 times the light only flashes quick after 5 seconds instead of staying on and allowing me to then proceed with the rest of the process to remove it.
boxpin
Oct 10, 2009 06:41 AM
rich nc
Mar 22, 2009 04:15 PM
whome
Oct 24, 2008 05:17 PM
master_pre
Aug 21, 2006 09:01 AM
bongo240
Apr 1, 2004 06:33 PM
