Sport / Econ switch no lights...
Old Jan 31, 2013 | 08:31 PM
mikesvagen's Avatar
Default Sport / Econ switch no lights...
My transmission mode switch does not light up in either sport or economy mode. I am net getting the arrow on the dash for winter mode either. All seem to function OK but no lights any ideas?
Old Feb 1, 2013 | 08:23 AM
mikesvagen's Avatar
Checked the obd1 box for codes not sure I i am doing it right but got none. Found a couple of threads on this but of course none ever posted as to whether they solved the issue or not. Swapped switch still nothing any ideas?
Old Feb 1, 2013 | 09:43 AM
ibified's Avatar
swap in a junkyard switch and see if anything changes.
Old Feb 1, 2013 | 10:03 AM
May have a TCM problem. I would disconnect the battery, pull the ECU boxes, make sure the prongs look good and hook it back up.
Old Feb 1, 2013 | 11:47 AM
mikesvagen's Avatar
will pull the ECU tomorrow rspi Thanks. I was thrown when no codes came up. Can transmission codes be pulled from obd 2 box on the 94 model?
Old Feb 1, 2013 | 11:55 AM
Yes...
Old Feb 1, 2013 | 11:59 AM
boxpin's Avatar
Bulbs do burn out.
Old Feb 1, 2013 | 01:07 PM
Originally Posted by boxpin
Bulbs do burn out.
Like he said. If you can feel the difference when you activate the switch it's more than likely it's just the indicator bulb in the switch that's bad.
I'm not sure if there is also a bulb that would illuminate it when the dash lights are on. Mine doesn't but I think it should. Maybe someone can clear that up
Old Feb 1, 2013 | 03:15 PM
mikesvagen's Avatar
Bulbs do burn out.
I have tried two switches. Once the second one which is a known good switch(saw it light up before removing it) did not turn on I posted here. Does winter mode light on the dash illumimate when the key is turned forward? If so that may be blown or disconected and gives me another place to turn.
Old Feb 1, 2013 | 03:54 PM
Does this help
In case you have a sharp eye, this isn't my panel it's a photo I borrowed. The Check engine light is a green kind of triangle, it's European.
Attached Thumbnails Sport / Econ switch no lights...-instrument-panel-metric.jpg
Old Feb 1, 2013 | 05:41 PM
mikesvagen's Avatar
Does this help
Awesome! my arrow does not come on at start up. I have another light out in the cluster so will be looking at that Diy as well.
So for plans this weekend.
1. go through the "pcv" system
2. get my horns working
3. change the gasket on my oil cap.
4. sort through the dash light situation
Old Feb 1, 2013 | 07:07 PM
mikesvagen's Avatar
And was going to tackle fog lights but not pre wired so ebaying the setup instead... DAMN!!!
Old Feb 1, 2013 | 07:10 PM
mikesvagen's Avatar
Was going to try and tackle fog light install but no prewired. So will ebay the factory setup and go with a nice set Piaa.
Mooman333
Oct 4, 2019 01:21 PM
Steve71
May 11, 2015 09:22 PM
Mr. Allvo
Feb 21, 2009 10:34 PM
sololight
Jan 6, 2009 05:09 PM
