sway bar
Old Aug 19, 2010 | 03:36 PM
dsniner's Avatar
Default sway bar
hi.. 96 850 wagon.. just noticed that the front sway bar has play in it. it moves form side to side. driver to passenger. a while ago i replaced the bar mount bushings with polly. does this matter or not. the bushing mounts have washers between the frame and the mount.. i could remove them to get a tighter fit. the poly bushing are the same id as the oem ones. thanks
Old Aug 19, 2010 | 03:57 PM
ibified's Avatar
there should be a little bit of play in it. as the car corners, there's generally going to be some (a small amount) of side-to-side movement. if it's not rattling, and your end links are good, I wouldnt worry about it.
Old Aug 19, 2010 | 05:32 PM
regime's Avatar
thats pretty much what i say. check the end links... maybe check out some HD ones if you think you need new... they dont cost that much more...
Old Aug 19, 2010 | 05:49 PM
dsniner's Avatar
sweet ,thanks!!
Old Aug 19, 2010 | 11:22 PM
boxpin's Avatar
I agree but the bar should not be able to move with your hands. If it does I would take those washers out.
urdrwho
Nov 23, 2014 09:49 PM
MikeNorris
Nov 9, 2005 01:29 AM
ray hummell
Sep 30, 2005 09:22 PM
dhines46
Jun 6, 2005 12:17 AM
RocknTommy
May 20, 2005 04:40 PM
