Synthetic oil
Old Aug 21, 2005 | 01:54 PM
Lichty17's Avatar
Default Synthetic oil
I have seen all of these adds for synthetic oils lately and i was wondering is it worth putting in my car? and if it is worth putting in my car what brand synthetic should i use? my car has 146000 miles
Old Aug 21, 2005 | 02:02 PM
Default RE: Synthetic oil
I like the Castrol brand for oil.
In my opinion Synthetic oil is well worh the money to buy and put in and it works good.
Other don't agree with me.
Old Aug 21, 2005 | 09:38 PM
robert213's Avatar
In my other car, I have had success with Castrol GTX. It is a in-line four with turbo. It has over 200K miles. No problems with original turbo. No problems with compression. I run straight 30W in the Summer and 10W30 when temperature high's stay below 60 degrees. I have always drained oil within 3,000 miles intervals.
My recent car was raised on synthetic by the previous owner, so I will stay with...
http://www.amsoil.com/storefront/amo.aspx
I am using Hastings Premium oil filters...
http://www.hastingsfilter.com/
The only possible problem with switching to synthetic at 146K miles, is that oil may begin to leak around valve cover gaskets and other oil seals. This typically happens to engines where the previous owner neglected to do routine oil changes. Go ahead and switch over to synthetic. If you have no problems with oil leaks, continue with synthetic. If you have problems, just switch back to conventional.
Old Aug 22, 2005 | 03:25 AM
Lichty17's Avatar
Yeah that is what my father has been telling me about synthetic. I guess its worth a try and if it leaks i will just go back. I use Castrol GTX rite now. Should i use Castrol's Synthetic? or does anyone have any other ideas for synthetic brands to use?
Old Aug 22, 2005 | 02:01 PM
robert213's Avatar
In no particular order...
http://www.redlineoil.com/
http://www.royalpurple.com/prodsa/auto.html
http://www.schaefferoil.com
BenHur
Sep 8, 2015 09:29 PM
Arsenal6
Apr 26, 2009 02:34 AM
aruizdelhoyo
Engine & Internal
Jan 15, 2009 09:26 AM
Mnvolvo1
Mar 25, 2008 08:42 PM
Viraaj
Nov 11, 2006 01:23 AM
