Trans position sensor
Old Apr 21, 2006 | 04:57 PM
skyman's Avatar
Default Trans position sensor
This morning I got in the car and started it and the amber arrow started flashing. This is the arrow that comes on when winter mode is selcted,except then it is on steady and not flashing. I tried shutting the car off and restarting it to no avail. I called the mechanic and he said to bring it over. He checked for codes and said it was indicating the sensor. He reset it and checked again and everything was clear and I drove away. I have not seen the problem again. He explained that it was basically saying it did not know for sure what gear the car was in. Rather then fool with it he ordered a new on to be installed on Monday. Is this just a 12 year old electronic part going bad or something common to the 850? The trans shifted normally and other then the flashing indicator I couldn't tell any difference.
Old Apr 21, 2006 | 09:16 PM
Default RE: Trans position sensor
That is normal on the older cars for them to go bad.
jonqu
Sep 4, 2013 12:45 PM
VolPat
Jun 15, 2012 08:06 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
VTBricked
Nov 21, 2009 07:50 AM
