Turbocharger Oil leak!!
Old Mar 11, 2007 | 06:15 PM
winm.'s Avatar
Default Turbocharger Oil leak!!
Hey there, I wasdriving my 1995 850 turbo and found there to be a large loss of power and black smoke pouring out the exhaust. I looking into it and found that the tubocharger is pumping oil right through the air system and making the vehicle run awful!!! I am not that knowlegable in the ways of the almighty turbocharger and was wondering if anyone has had this problem and knows what the F#*k is wrong with it.
Old Mar 11, 2007 | 06:33 PM
S70driver's Avatar
Default RE: Turbocharger Oil leak!!
RMS maybe
Rear Main Seal
Old Mar 11, 2007 | 06:49 PM
winm.'s Avatar
Sorry, I don't understand. How can there be oil coming out of the turbocharger be in relation to a rear main seal?
Old Mar 12, 2007 | 08:39 PM
Vent system might be clogged.
Old Mar 12, 2007 | 08:41 PM
S70driver's Avatar
ORIGINAL: winm.
Right here.
http://www.ipdusa.com/ProductsCat.as...amp;RootID=629
"Turbo Drain Pipe Seal Kit Got Leaks?
Lately we’ve noticed that many of the newer Turbo Volvos have a tendency to leave oil drips. Usually, the amount of oil loss is minimal, but the mess is still bothersome. In many cases, the oil drip is coming from the turbo drain pipe seal (located near the center back side of the engine). We put together this kit with instructions so that you can fix it yourself. In less than an hour you can have it repaired. You may need a 5mm Allen wrench (or Torx on some models) and 10mm socket. Check your cars fasteners before getting started to be sure you have the tools needed."
Old Mar 12, 2007 | 11:31 PM
winm.'s Avatar
Oh, I thought you ment the rear main seal between the engine and the transmission. The oil leak is very very quantitive to the point where oil actually pours out of the weep hole in the air cooler in front of the radiator!! this is more than a drop here and there. but again I am not that knowleged when it comes to turbo units so any kind of help comes in very handy.
chaz069
Mar 11, 2015 06:47 PM
russ g
Jan 23, 2011 07:50 PM
thesaintnr1
Mar 17, 2006 01:33 AM
CARSLAVER
Sep 21, 2004 02:38 AM
tenshiwingusu
Apr 19, 2004 08:39 PM
