Unofficial 855 Project Threadz
Old Feb 25, 2010 | 03:01 PM
  #201
Legendsecko87's Avatar
I think I know what I'm going to do for my foglight switch, but I just wanted to let Gilber know what I'm doing for a switch. The only thing i have in question is how the dash light will light up with the fog light switch is on. What I just tested to see if the heated seat switch works with the rear fog light and it does. This has the LED that lights up when it is in the on position. You can try and piece togeather your own switch by using the heated seat switch with the fog light face plate to get that light up that Boxpin has.
Old Feb 25, 2010 | 03:05 PM
  #202
gilber33's Avatar
I have the oem fog light switch, I just didn't have the connector on the harness that everyone else has. But I guess 94s are different and in order to hook up the fog light switch you need the harness that connects to yellow plug under my dash (that's what the picture is).
Old Feb 25, 2010 | 03:40 PM
  #203
Oh poo. I have to figure out how to do mine :P Why do us 94-ers have to be so screwed over? Haha.
Old Feb 25, 2010 | 04:31 PM
  #204
gilber33's Avatar
Search ebay for it, I think that's where the guy said he got it, or give the dealer a call, see how much they want for it. I know though, it's really dumb, but it makes sense. I think it wasn't until 95 that the Volvo had a model in the US that came stock with fogs, which was the T5-R. I"m guessing a lot of the Euro 850s probably had fogs in 94. So when 95 came around and they were making cars with stock fogs, they probably just threw the connector on all the harnesses for production reasons. That's my guess.
Old Feb 25, 2010 | 04:59 PM
  #205
Hmm, wierd. I found a 84-850 with fogs and rear mudflaps stock so I think I'm going to go check it out sometime. (Junker)
Old Feb 25, 2010 | 06:16 PM
  #206
gilber33's Avatar
If it has fogs, grab the harness.
Old Feb 25, 2010 | 06:50 PM
  #207
boxpin's Avatar
Grab the rear mud flaps...I have been searching
Old Feb 25, 2010 | 08:25 PM
  #208
Gilber: It has fogs. Get me a diagram of which wires exactly you need and I'll do it. I'll call and ask how much he wants.
Boxpin:I think you can get them fairly cheap from the dealership new. I called in a few weeks ago and they wanted around 45-55 for the set. I think this guy wants 15 a piece for it, so PM me know if you really want it and I'll let you know.
The thing that sucks about this is that it is not a pick and pull
Old Feb 25, 2010 | 08:55 PM
  #209
gilber33's Avatar
I'll already sent the guy money for the parts. I'm getting the harness/plug connector and all relays brand new for 25 shipped. Go snag that stuff for yourself man, get the fogs and everything.
Old Feb 25, 2010 | 09:01 PM
  #210
Originally Posted by gilber33
See previous post, if you have that giant yellow plug that I showed, yours may be the same way. This guy has all the harnesses/relays needed to install the fogs this way NEW that he's giving me for really cheap. YAY. I tried taking pictures but it's really hard when I can't even fit my head underneath the front bumper anymore. I'll try again later today.
215s? They do look really good on the wheel. I think I'm going to go with 195/45/17. 205 at the biggest.
I am running 215/45/17's om mine now with the aftermarket wheels and no rubbing at all.
Old Feb 25, 2010 | 09:05 PM
  #211
gilber33's Avatar
I want a tad of stretch though. I think the 195/40/17 look's sexy on this size wheel, but I don't think it would look good without a serious drop. I want some tire tuck in the fenders, and I don't know if you would get that with a 40 or not. Tyrestretch.com gives you a good idea of tire size on wheels.
Old Feb 25, 2010 | 09:13 PM
  #212
I know one thing you will get. That is a SH**** ride!
I am running 205/40/17's on my stock wheels at this moment and it is Horrible!!!
You can almost feel every pebble in the road. You will also have to watch really good. If you hit a pothole you can bend a rim or blister a tire. I have blistered 3 205's already due to potholes.
Old Feb 25, 2010 | 09:19 PM
  #213
gilber33's Avatar
Maybe I'll stick with the 45s then. I'm not going bigger than 205 though. Plus I'll be riding on Bilstein HDs, so I'm already in for one bumpy ride, but I'm fine with that.
Old Feb 25, 2010 | 09:23 PM
  #214
gilber33's Avatar
Oh, and only one more wheel to prep and then they're all ready for paint, which is probably happening this weekend. At least the primer and base coat. Don't know if I'll get to clear or not.
Old Feb 25, 2010 | 10:10 PM
  #215
Well good luck on the combo. After running the 215's now I would never go back to 205 unless they are FREE.
Old Feb 25, 2010 | 10:17 PM
  #216
I have no reason to grab the fogs. I already have fogs that outperform the stock projectors! I might grab the harness though. I kind of want a foglight switch. I'm thinking about making my own anyways. How much can these switch handle amphre wise?
Old Feb 25, 2010 | 10:19 PM
  #217
If you can see how much they want for the fogs.
Old Feb 25, 2010 | 10:33 PM
  #218
Alright, you interested in a set?
Old Feb 25, 2010 | 11:16 PM
  #219
boxpin's Avatar
Nowhere close to powering a 55w+ bulb. Use a relay or burn up your switch.
Old Feb 25, 2010 | 11:53 PM
  #220
Thats what I thought. relay it is. But are you interested in rear mudflaps? I gotta figure out if I need to take a run up to North Seattle.
