Volvo 850 ECC - Blower always on high
Old Feb 29, 2020 | 12:37 PM
Alex Cat's Avatar
Default Volvo 850 ECC - Blower always on high
I've read many posts on here and other forums about this issue but still haven't managed to resolve it. I picked up a replacement resistor from the scrap yard but that hasn't fixed the issue. It could be that the replacement resistor I got from the scrap yard is also defective but before buying a new one (they are expensive) I'd like to troubleshoot to see if the issue is coming from elsewhere. Here are some of the symptoms and fixes I have tried so far.
1) A/C and Recirculate LEDs do not flash or come on at all.
2) Blower motor on high once key is turned in ignition
Fixes tried:
1) I have tried to switch the J relays around
2) replaced resistor with one from scrap yard
Once thing I have noticed is that the actual ECC unit is defective since none of the lights on A/C and recirculate come on?
Old Mar 1, 2020 | 11:52 AM
The resistor is used to control the lower fan speeds and is bypassed when the fan is on full. Have you tested the relay, checked all fuses? Did you test the replacment and old ballast resistor to make sure both are in working order? Its possible the ECC unit has failed so if you have access to a used module from the yard or ebay, that may be the next step.
You may find some diagnostic tests at Volvotips.com (online shop manuals for the 850s and others).
Old Mar 8, 2020 | 03:23 PM
Alex Cat's Avatar
I just received a brand new resistor and problem persists so it doesn't come from there. Fuses are good too. Which relay are we talking about? The J relays or the relay that it to the left of the blow motor? Any other ideas before I go to by a ECC unit?
corker
2001-2013 model year V70
Apr 20, 2016 06:31 AM
itsneddy
Jun 19, 2013 03:04 PM
grigalid
Sep 16, 2010 11:26 PM
redblock
Nov 25, 2008 07:20 PM
Dads850
Sep 29, 2006 09:38 PM
