Engine Management
Old May 31, 2018 | 07:31 AM
Metrix84's Avatar
Default Engine Management
Hi all, first post so be gentle.
I'm hoping you may be able to help work out whats going on with my engine before having to take it in to my local garage and get charged an arm and a leg in labour for diagnosing.
Approx a month ago I noticed the engine management light show on my 2010 Volvo C30 T5 R-design, I plugged in my Fault Code reader to find it was stating:
  • P2178 - System Too Rich Off Idle (Bank 1)
I called my garage who said to clear the code and keep driving as it was a common fault and I shouldn't be worried but to phone back if it reappears. Approx a couple of days ago the light reappears and I plug the diagnostic in again and I now have 5 codes:
  • P0191 - Fuel Rail Pressure Sensor Circuit Range/Performance
  • P0089 - Fuel Pressure Regulator-Performance Problem
The oil temps are fine and it has plenty in as well as cooling fluid. There is no loss in performance not that I've been driving her fast after seeing this light come on.
Any thoughts would be appreciated.
Old May 31, 2018 | 09:46 AM
sounds like the fuel pressure sensor needs replacing. You didn't mention what engine or year car but check out Volvo friendly parts sites like FCP Euro or EEuro Parts. It should be a 15 minute fix (vids on Youtube). Part should be under $50 for OEM Bosch, over $100 for Genuine Volvo...
Old Jun 2, 2018 | 11:56 AM
Metrix84's Avatar
Anyone?... Anyone?... Bueller?
Old Jun 2, 2018 | 06:55 PM
tryingbe's Avatar
Call the garage again and set an appointment.
Old Jun 10, 2018 | 04:34 PM
tony1963's Avatar
If the fuel pressure sensor is out then it probably has a default to at least keep the car running, but the pressure is probably too high for idle.
You can either guess and try and fix this yourself or seek a professional. I do not recommend that DIY projects include any fuel related work because of the hazards involved.
Pay for a proper diagnosis and repair.
mwbridgwater
Nov 30, 2014 02:12 PM
eztechsmart
Mar 27, 2013 08:53 AM
ThomasK
Mar 4, 2012 09:38 PM
dave9170
Sep 5, 2011 11:37 AM
apexnut
Feb 2, 2010 08:42 AM
