C70 door unlocks and opens itself while driving.
Old May 29, 2023 | 04:29 PM
  #41
Cartesio64's Avatar
Default not sure but...
I had the some problem to the driver's door many times for 2 years, but I kept it unresolved, then last year I had a fault to the clutch and the Volvo assistance repaired it. Since that time to now the problem disappeared, I suspect that it was due to the door harnesses and related interferences, as they disassembled and reassembled many parts near the driver's door and so they unintentionally resolved also the door's problem.
Old Jul 7, 2023 | 08:31 PM
  #42
mlessard00's Avatar
Default 2013 C70 - unlocking problem
This unlocking problem appeared two years ago and is on and off, only with the driver's door, and with the top down. Today, while driving to the dealer for another problem, on a beautiful sunny day, it happened four times over a one hour drive, and in one occasion, it was the passenger's door.
The dealer suggested to replace the two latches, at CA$239 each, plus one hour per lock for labour. I'll try the other solutions mentioned in the previous chats. It really seems to be related to the car lack of structural rigidity while the top is down. I noticed it could be related to speed, bumps, and other stresses on the car's body. Will keep you posted. Was glad to see that others have been able to resolve this problem.
Old Jul 21, 2023 | 08:44 AM
  #43
IFixMyOwn's Avatar
Default 2012 and 2013 C70 - unlocking problem
Had a 2012 that got wrecked, badly. Car was totalled with really bad damage to the front, the driver door and trunk. Interior looked like you could drive it away. Thank goodness my wife came out unscathed. We found and purchased a used 2013 Inscription. I have the same problem here with both doors but is more common on the passenger side and only when the roof is down. The 2012 did it as well as the 2013.
Old Jul 29, 2023 | 12:21 PM
  #44
d.pharand's Avatar
I had that problem 2 year ago I sprayed lot of silicone lubricant directly into the latch and my problem is solved since 2 years
Old Apr 7, 2024 | 12:11 PM
  #45
echocheryl's Avatar
Default C70 door unlocks and opens while driving
Originally Posted by mamabear96
Hi, has anyone with C70 (2013) ever have this problem? I was driving long distance this weekend, about 4 hours, my car doors unlocked and door was ajar while I was driving. It happened 4 times. I had to pull over and close and lock the doors again and again. It didn't do that when I drove home with the top up. It only did that when the top was down. I'm baffled and frustrated. Any idea?
My 2012 C70 has been doing the same thing for about the last 6 months. Not every day and does not matter if top is up or down It is a dangerous thing however. I am wondering if there is a recall on this issue?
Old Dec 15, 2024 | 04:06 PM
  #46
Cartesio64's Avatar
I had the same problem, I successfully tried with some rounds of paper tape around the little bar of the part of lock on the vehicle side (i.e. not the door side) and it seems working. The reason why is probably that tape compensates some mismatch and wear and tear of the parts of the lock.
Harvir
Dec 9, 2015 07:06 AM
mkinsocal
Aug 9, 2013 02:27 PM
TimDavis
Jun 18, 2013 09:03 PM
liweih21
May 2, 2013 03:06 AM
VTC70
Jun 23, 2010 07:46 AM
