interior panel removal
Old Mar 7, 2014 | 10:56 AM
Robert A. Koenig's Avatar
Default interior panel removal
Anybody help me to remove the interior door panel on my C70 (2011)
Trying to remove to put new door handle on.
Old Mar 8, 2014 | 10:26 PM
mikeles's Avatar
you tube it?
...m
Old Mar 8, 2014 | 10:43 PM
damien360's Avatar
The for handle is part of the door panel. Do mean interior door lock?
Old Mar 9, 2014 | 09:56 AM
Yes I'm trying to replace the door handle on the inside of the door.
Old Mar 9, 2014 | 09:57 AM
Default Replace door panel
Originally Posted by mikeles
you tube it?
...m
I've tried and have no success
Old Mar 9, 2014 | 11:38 AM
damien360's Avatar
Are you taking about the actual handle in which you hold on onto to close the site or the lock assembly
Old Mar 9, 2014 | 11:43 AM
damien360's Avatar
Sorry I didn't see your updated post on my first question. The interior door handle is part of the door panel and as far as I know it can't be replaced separately.
To take out the door panel you need to lift the chrome trim on the handle itself to reveal the 2 T25s and then you just pull the panel off.
Old Mar 9, 2014 | 06:37 PM
The one used to close the door. I've removed the cover and than the 2 bolts underneath, the speaker grill and NO luck. The small handle for the door luck is I believe holding it in.
Old Mar 10, 2014 | 07:06 AM
Thank you for your input, I've tried this but you have to remember that the handle also houses the handle that opens the door along with the speaker to the right of the handle to close the door.
Just for anybody's info the part number for the handle replacement is
P/N 39823730 $70.48 cost
I am pretty sure you have to take the door panel off to get to the handle to open the door due to a rod attaching to it to unlock the door.
jrcochranusa
Feb 19, 2010 02:30 PM
netconcepts
Oct 29, 2007 09:57 AM
ko_kidd
May 18, 2007 02:36 PM
yellow95
Apr 19, 2006 09:05 PM
volvo13
Apr 17, 2006 07:55 PM
