MY C70 UPGRADES
Old Feb 24, 2009 | 06:16 PM
  #201
PANTYEATR's Avatar
yeah, the turbos of those times were rude and crude! they have come such a long way since then. they actually have a CAST stainless steel turbine housing now that makes the turbo so light, that cracking exhaust manifolds are a thing of the past.
the turbo is considered 1/3 of an actual muffler, so really you don't have to run a muffler at all, but the sound can be improved with a preforated, straight through exhaust like the one i'm putting together. a flowmaster or anything like that would surely hurt performance. turbos hate baffles and chambers.
here are my star players
this thing is gonna sound good!
Old Feb 24, 2009 | 06:24 PM
  #202
TIPSP's Avatar
Got Boost?
Awsome! post a video when complete!
Old Feb 24, 2009 | 06:28 PM
  #203
PANTYEATR's Avatar
i'll have to figure out how to do that now that i have a digi cam that can make movies.
Old Feb 25, 2009 | 12:45 PM
  #204
reg's Avatar
reg
Why not bend stainless pipes?? I recall you mentioned aluminized?? I had a stainless system made for the hartge. I used Porche tips (dual tips) for the ends of the two mufflers and cut the rear valence for a custom fit. The rear mufflers are oblong (ie: not round) and have no baffles..............the core is perforated and the body of the mufflers are packed with long strand glass. A great idle sound and awsome when under full tat. Realize Eater that I can hit 10000 RPM although at 150 MPH I am at a tad over 7000. I'm waiting to see your finished product and can well imagine that it will be professional!
r.
Old Feb 25, 2009 | 08:05 PM
  #205
PANTYEATR's Avatar
well i will have to see the difference in cost between the aluminized and the stainless. i want the stainless, but if the aluminized is a good value i'll go with that just to compete with the cost of the OBX system.
my goal is to make an exhaust system that will beat the OBX in price and performance. (i already blew the price part out of the water)
build it exactly the way i want and be good for a good stretch of power levels.
i will have my friend TIG weld the whole system, it will be very nice Reg.
Old Feb 25, 2009 | 08:40 PM
  #206
Is that the same friend that might be able to weld my rims?
Old Feb 26, 2009 | 04:21 PM
  #207
reg's Avatar
reg
Eater, go to a metal shop/machine shop and purchase your stainless. That is what I did and then had it bent at a quality muffler shop. I had a friend weld up the 'pieces' and then I sent the whole 'thing' to Jet Hot in Mississippi. By buying the pipe yourself, you will find the cost is quite competitive with what a muffler shop will charge for aluminum. By the way..........the reason I Jet Hot coated the parts was to get a better flow through the pipe. My header is stainless and I had it Jet Hot coated and the under hood temp dropped quite a bit. Something for you to consider.
r.
Old Feb 26, 2009 | 04:48 PM
  #208
PANTYEATR's Avatar
yeah, thats the guy. he wants to TIG the whole thing, but it will be a 2 piece exhaust just so we can remove it for whatever reason.
that sounds like a good idea Reg, but we don't have too many mandrel bender guys here in orlando. they barely carry bent pipes with no reduction or crimps in the bends. i'm so ready to do this, i can't wait! i wanna hear what this thing will sound like once i free up these HPs
Old Feb 26, 2009 | 07:49 PM
  #209
Let me know next time you talk to him. I can also e-mail a pic of the rim to just get an idea of how much to fix them.
Old Feb 27, 2009 | 10:32 PM
  #210
PANTYEATR's Avatar
wow!!! these HIDs are like night vision X 10! if the 8Ks look this good i can't imagine what the 4Ks look like.
i'm stll learning my new digi cam so i'll try to get some good pics of the colors and light output. whoa!!!
Old Mar 17, 2009 | 07:52 AM
  #211
ICE's Avatar
ICE
Originally Posted by DJRUZERS6
hey mate I was reading through all your posts and was wondering how this pod is ? its something i was looking at on IPD and was a bit skeptical. what are the differences ? performance ? noise ? cheers
oh by the way Ive decided im in love with your car ! mmmmm
Old Apr 9, 2009 | 07:14 AM
  #212
povar's Avatar
Save your money for a BBK. Don't waste it on some x-drilled or slotted or x-drilled/slotted rotors now.
Old Apr 11, 2009 | 11:57 AM
  #213
PANTYEATR's Avatar
Default My 3" exhaust build
well finally! i built this 3" exhaust for my C70 yesterday and i'm pleased. a very special thanks to my very good friend Jon Adams of Pro Tree Kustoms for making this possible and seeing my lengthy project through. heres the pics of the build enjoy.
heres my friends shop contact info, if your in florida this is the guy you want doing all of your custom builds or basic repairs. he's a perfectionist with over 25 years experience!
first we had to get the car as high as we could since he doesn't have lift yet.
getting the stock exhaust out wasen't too bad. it comes out in 2 pieces and that bolts were nice to me and didn't require too much PB blaster to get out.
here are the materials, a mandrel bent pre-built tail pipe section for a pick-up truck (why? cause it has like (6) 45 degree bends in it for like $90. try and buy thouse bends seperately and you'll be way over that) some hangers, 2 O2 sensor bungs, a new rear O2 sensor, a magnaflow street muffler, CAT and pre-silencer, flexpipe, a 90 degree bend ( i recommend you get 2 of these, i only had one) a 10' straight and a reducer from 2.5 - 3" (which i didn't need, but i wasen't sure about the turbo outlet size)
i had some people ask me "what are you gonna do for a downpipe flange?" my answer is hell use the one volvo gave me ;P these factory flanges have a step in them that seals the exhaust to the turbo without the need of a gasket.
bolt the flange back on and let the fitting begin
once we found the angle to shoot the pipe between the firewall and the engine cradle it was time to weld. the flange welded up to the pipe very well, so it doesn't appear to be a cast iron part.
the downpipe was built with the O2 bung, flex pipe and CAT all in
the rear O2 bung need some special consideration. i wanted to put it in a a 3'o clock postion to make it easy to get to for service if it ever needed changing. putting it at 3'o clock though will not leave you with enought room to get it out in thin tunnel, so Jon built this 45 degree angle out of the some of the pipe we cut and made this custom piece.
heres most of the exhaust in the tunnel from the front
heres the complete exhaust on the floor after all the welding. looking good and smooth flowing.
heres the exit. it's tilted alittle cause the car is higher in the front than the on the jack stands. later we will make it more level once i buy another 90 degree to make the bend.
so, how much did all of this cost and how does it sound? well i know there will be people out there that will say i should have just bought the OBX kit and called it a day, but i say NAH!
i had everything built the way i wanted, with the parts i wanted, not the way OBX wanted it or wanted to put in it. the experience was great and it was a fun build. plus i did this completely 3" from the turbo back so, that means i have alot of performance upgrade room, pretty much i have to let the engine and turbo grow into the exhaust :P
the car sounds alittle louder than a stock G35 at WOT. and it's cool cause remember i'm running stock boost on a LPT. crank the boost to 14 psi with some ECU tuning and it will sound really good.
the damage:
90 degree bend - $25
double wall flex pipe - $74
truck tail pipe section - $90
O2 bungs - $2 each
(7) hangers - $5
rear 4 wire O2 - i have 2 already $0
10' straight - $25
magnaflow 3" CAT - $75
magnaflow 3" pre-muffler -$75
magnaflow 3" street muffler w/ 4" tip - $125
total = $493
yeah alittle bit mre than the OBX but way cheaper than the IPD or euro sport. over all. i'm happy.
Old Apr 11, 2009 | 12:17 PM
  #214
Looks good.
Old Apr 11, 2009 | 10:56 PM
  #215
TIPSP's Avatar
Got Boost?
Looks great!
Now We need a video!
Old Apr 12, 2009 | 12:06 AM
  #216
PANTYEATR's Avatar
tell me how to make a clip and post it
Old Apr 12, 2009 | 12:27 AM
  #217
Upload it to you tube then link it to here.
Copy and paste the link here.
Old Apr 12, 2009 | 05:14 AM
  #218
ICE's Avatar
ICE
Hey mate, Im looking at doing this myself, was there much of a power difference ? ...boy it does look good though
Old Apr 12, 2009 | 07:51 AM
  #219
reg's Avatar
reg
Nice job Eater!! Custom is always the way to go.............don't be a lemming and follow the rest! I am a tad concerned about premature rusting. I would have sent the unit to Jet Hot for a coating inside and out.............better flow. What's next?
reg
Old Apr 12, 2009 | 09:27 AM
  #220
PANTYEATR's Avatar
i'm not sure about the power increase cause i didn't dyno it to verify, but as soon as you touch the gas the car now snaps to get going. on the highway, drop the hammer and it pulls noticably harder, not neck snapping but harder than before. it's very easy to hit triple digits now.
thanks Reg, i agree with you, but if money and time wasen't a thing i surely would have had it coated.
whats the next thing hmmm............i want to build and intake for it, but the way i wanna do it will require some time and reasearch. i really need to finish my interior. i want to increase the boost with a MBC, but i will need a boost gauge and a nice pod set-up first.
or i can start with my vented / lovered hood and duck bill spoiler mods and painted center. who knows what i'm gonna do next, but when i know you will for sure
