No speedometer, odometer, trip or cruise.
Old Mar 8, 2021 | 11:29 AM
Logan Gibson's Avatar
Default No speedometer, odometer, trip or cruise.
2004 Volvo C70, 2.3 AW55
I had a wheel bearing replaced in august, noticed right after the abs and stc light would pop up after hitting a bump, would shut the car off and it would reset, abs would only stay for a couple seconds after driving, finally got around to it last week suspecting it was the abs module, cracked open the abs module to check any bad solders, didn’t see any so I put it back it in to try it. Abs, brake and cel reading P0504 popped up so I replaced the module thinking I messed something up within the module, same thing, odometer pops up for about 5 seconds then goes to slashes, also I hear some sort of wiring noise coming from the radiator area and as soon as the noise stops the odometer goes to slashes, I’ve replaced the brake pedal position sensor and no luck, any help would be greatly appreciated
Old Mar 8, 2021 | 01:20 PM
Your first step would be to connect a compatible scan tool to view live data and see if there are any codes stored BEFORE you replace any more parts on a guess (it can get really expensive fixing cars that way!)
greenS70
May 13, 2009 07:59 PM
vanagon
Apr 12, 2009 10:43 PM
EATMAN
Jan 29, 2009 12:50 PM
toytruck89
Oct 7, 2008 07:50 AM
veso_ht
Oct 21, 2006 12:09 PM
