2001 radio amp location?
Old Jan 15, 2019 | 01:19 PM
scfanning's Avatar
Default 2001 radio amp location?
Could someone please tell me where the radio amp is located in the 2001 s40? I was just gifted the car and there is no audio but the radio seems to be working according to the display and I think it might be the amplifier.
Old Jan 20, 2019 | 10:12 AM
It should be part of the head unit - you may want to pull the unit out (make sure you have the code first!) and test directly with some speakers. worst case is you buy a replacement on eBay (again, make sure the seller provides the code) - they pop in/out with the two metal tabs on the outside then slide out - there's standard Volvo connector plus the antenna so other "double DIN" models can be used.
Old Jan 20, 2019 | 11:55 AM
scfanning's Avatar
Thank you! I do have the code.
sandij2004
Jun 23, 2010 08:47 AM
lurbina
Nov 8, 2009 10:16 AM
lker2001
Mar 7, 2008 08:04 PM
dsniner
Dec 12, 2007 11:37 PM
GaryBrad
Feb 13, 2006 11:27 PM
