S40 Vibration
Old Nov 26, 2005 | 03:08 PM
airapetov's Avatar
Default S40 Vibration
I have a 2000 Volvo s40 1.9 turbo it has 93,000 miles on it.
My question is that my car begins to vibrate when I reach 45-65mph.
When I accelerate I can fell the steering wheel shake and it fells like my tires are bouncing up and down. As soon as I let go of the gas, the car runs smoothly as though nothing is wrong.
All the engine mounts and front axles have been replaced.
I thought it might be the tires needed balancing, but I had the tires rotated and balanced and the problem persists.
Thanks for any advise,
Roman
Old Nov 27, 2005 | 01:44 PM
finchy's Avatar
Default RE: S40 Vibration
I had a similar problem once on one of my previous cars. How worn / old are the brake disks? (Rotors), The problem I had came down to the fact that the disks (Rotors) were warped!! The disks were that bad that every time the wheels rotated it was knocking on the brake pads causing the vibrations, so at 40 - 60 mph the amount of times the wheels turned full cycle the vibration is pretty bad, then obviously felt through the steering wheel!!
Hope this helps.
Finchy
Old Nov 27, 2005 | 08:34 PM
You should have the new Axles checked. I have seen new axles go bad and cause the same vibration.
I have also seen the transmission break something inside and give alot of slack on the drivers side where the axle goes into the trans.
Old Nov 28, 2005 | 12:53 AM
airapetov's Avatar
Thanks for your reply.
I will check the brake disks this week.
Thanks again,
Roman
Old Nov 28, 2005 | 12:57 AM
airapetov's Avatar
I founf out that only left axle has been replaced. I'll check with technician who replaced it to chek the both axles.
Thanks again,
Roman
Old Dec 19, 2005 | 10:51 PM
airapetov's Avatar
Could it be faulty transmission or differential?
Old Dec 19, 2005 | 11:33 PM
I have seen the trans break before.
Old Dec 19, 2005 | 11:54 PM
airapetov's Avatar
When you say trans break, that means transmission needs to be replaced?
Old Dec 19, 2005 | 11:56 PM
Yes but if that happened then you would feel SLOP in the Axle where it goes into the trans. Up and down slop not turning slop or in and out.
Old Dec 20, 2005 | 12:11 AM
airapetov's Avatar
I'm sorry, but i didn't get it. What slop?
All I feel is vibration when i push accelerator after 45mph.
thanks
Old Dec 20, 2005 | 12:23 AM
You would have to feel for slop at the trans where the Axle goes into it.
jasonl
Nov 23, 2008 12:00 PM
ocean238
Apr 17, 2008 06:20 PM
halo2maniak
Nov 20, 2007 11:01 AM
yuriy36
Oct 14, 2007 05:43 AM
ohskigod
Oct 23, 2006 11:15 PM
