Overhead Light console
Old 07-13-2018, 06:16 PM
Jbraight's Avatar
Default Overhead Light console
The clips on my overhead night console all broke off and was just hanging when i walked out of work one day. Anyone know where I can just buy the plastic housing? Components and electronics are still working so i only need the plastic housing.
Old 07-13-2018, 07:51 PM
habbyguy's Avatar
That just happened to mine, too. I found a used one on Ebay. It's a slightly different configuration (has a sunroof button, while my car doesn't have a sunroof), but I figure that I can reuse just the plastic housing and relocate the actual electronics into the new housing. I think it cost about $65 delivered. There should be plenty in parts yards, as well (if you're not too picky about color, especially).
Old 07-14-2018, 09:14 AM
pierremcalpine's Avatar
Ebay prices will be double/even triple what it will cost you to visit the closest “pick-your-own” wreckyard. Just head over and rip one out. Will likely cost you no more than $5.
Old 07-14-2018, 01:34 PM
habbyguy's Avatar
The boneyards around here would charge a LOT more than $5 for an overhead console, FWIW... still cheaper, but when I factor in the time and effort, the $55 (I just checked) I paid was a relative bargain, especially since I can likely sell the sunroof switch and maybe other bits I didn't need.
FWIW, I bought a sunroof version of the panel (I couldn't find a non-SR panel), and it took me 5-10 minutes to swap over the black trim panel and remove the sunroof switch. Now I have an un-cracked console that's flush against the headliner. Speaking of which, one of the problems that the previous owner / mechanic had installing the old console was that the headliner material was cut sloppy, and obscured the female catches for the plastic tabs, which (I suspect) caused them to snap off when he tried to force the panel into place. I trimmed the headliner up with a razor knife, and the "new" one went in like butter...
habbyguy
08-11-2018 09:38 PM
kg4ibj
10-02-2013 02:48 AM
saberjk2
08-14-2013 12:59 PM
rspi
08-29-2010 01:59 PM
surfaccing
03-27-2010 07:09 PM
Quick Reply: Overhead Light console
