volvo s40 2001 vibration
Old Apr 6, 2009 | 08:21 AM
hurin1's Avatar
Default volvo s40 2001 vibration
ok i make it clear...the vibration occure when i accelerate at 60-70 km/h and continu until i stop too accelerate. I check all the brake, disk and i balanced my wheel...so some people say axle other say engine mount...someone who have this probleme and solve it can tell me what it be....sorry for my english
Old Apr 6, 2009 | 04:21 PM
sotexasS40's Avatar
How many miles do you have on your car? Does it grind while accelerating from a dead stop?
Old Apr 6, 2009 | 06:20 PM
hurin1's Avatar
i have close 200 000 km and it's shacking only when i go around 60km/h and more when i accelerate only
Old Apr 6, 2009 | 08:54 PM
ndloewen's Avatar
My does/did the same thing. I had an engine mount that was missing and had that fixed but it did not fix the problem. I had my CV axle checked out and it is getting replaced tomorrow. I will post after that to let you know more for sure.
Old Apr 6, 2009 | 09:37 PM
hurin1's Avatar
thank you please tell me after you replace your cv axle....lot of people have this trouble but no one give the solution clear...and the probleme is exacly the same for every body
Old Apr 7, 2009 | 08:05 AM
sotexasS40's Avatar
Replacing the engine mounts might help w/the vibration. Just replaced my transmission mount and that helped a lot w/the grinding at low speeds - and high-speed vibration during acceleration. Hope that helps.
Old Apr 7, 2009 | 08:28 AM
sghokie's Avatar
On another car (honda) I had replaced the axles with aftermarket ones because of the boots tearing open.
Well after a few weeks the car did the same exact thing, vibrating on acceleration.
I didn't know what was wrong, I took it to the stealer and they proceeded to try a bunch of different things. But it was still messed up.
So I decided to replace the axles with honda parts.
Problem cleared up and never came back.
Old Apr 7, 2009 | 07:00 PM
ndloewen's Avatar
Default vibration fixed
I had a new Right Front axle assembly put in today and it completely fixed the problem. The mechanic said that the boot had pulled away and that the vibration was being caused by the inner joint catching and vibrating. Sure enough he was right took it straight to the highway and no vibration. cost of the repairs here in texas was parts and labor $530 dollars. Hope that helps.
sail29
Dec 13, 2012 11:56 AM
snpklinefelter
Mar 1, 2009 08:43 AM
ocean238
Apr 17, 2008 06:20 PM
yuriy36
Oct 14, 2007 05:43 AM
YUKON
Sep 22, 2006 08:40 PM
