2002 T5 sunroof leak.
Old Aug 26, 2012 | 05:41 PM
vol341's Avatar
Default 2002 T5 sunroof leak.
I'm sure somone on here has had this.. mostly on passenger side.. entire ceiling soaked after rain.. even running down the passenger piller by the window.. is this a simple fix? Or would i have to take it somewhere?
Old Sep 13, 2012 | 09:54 AM
patsfn2's Avatar
I would take it to a shop that does upholstery and installs sun roof...i.e. seats, replaces headliners in cars, they can drop down your headliner and use a hose to see where it is leaking, they should also be able fix it for you...I am not sure how much it would cost but my friend has a shop and they also install sun roofs and they found and fix a leak I had in my wifes Explorer......hopefully you have a shop like this near you and they can find and fix your leak! I hope this helps
Old Sep 13, 2012 | 10:42 AM
Usually one of two problems, blocked drain or leaking seal. Slide the shade back and put some water on it. If u see it leaking on the glass it's likely the seal. If you can't see the leak, likely the drain is clogged. Then clear the drain. You can also open the roof and pour a cup of water in the track to see if the drain is clogged.
http://atthetipwebs.com/technologyin...eak_repair.htm
Alun J
Jun 22, 2015 10:43 PM
drdave408
Mar 25, 2014 03:38 PM
ikes4ever
Nov 17, 2008 08:40 AM
volvokidkyle18
May 12, 2008 01:34 PM
Lichty17
Aug 29, 2005 09:48 PM
