Ignition switch won't turn
Old Aug 31, 2008 | 12:32 PM
NDan85's Avatar
Default Ignition switch won't turn
Have a 2001 S60, 75k miles. When I put the key in, sometimes the ignition switch won't turn. I jiggle the steering wheel and also the key in the ignition, but the ignition is locked up. Eventually, I seem to find the right spot while jiggling the key and the switch turns. I'm afraid this will continue to get worse.If I have to start putting a lot of money into it, I may sell it. Is this a common problem? Any recommended fixes?
Old Aug 31, 2008 | 10:23 PM
Default RE: Ignition switch won't turn
Common problem and it needs a lock cylinder assembly. The entire assembly.
Old Sep 1, 2008 | 10:08 AM
NDan85's Avatar
thanks
phil.crawford1
2001-2013 model year XC70
56
Aug 2, 2024 04:06 PM
Edashcash
Jun 8, 2008 12:39 AM
Carbuff
Jun 29, 2005 11:42 PM
