Shaking in my s60
Old Mar 16, 2011 | 12:44 PM
Kgoncalves's Avatar
Unhappy Shaking in my s60
So my 2003 s60 has been shaking while accelerating for a while now. Before it was just a light shaking, so I got tires rotated, balanced, and aligned. I moved uP to Georgia, and when I took it on the highway I felt as if my car was going to fall apart it shook so much. I noticed a weight fell off one tire so I got that balanced and put a weigh back on but it's still shaking only when accelerating. I'm not sure what else to do. The guy at Goodyear says I need two new back tires but I just had it appraised yesterday and they said it was fine. What could this shaking be? Even the mechanics at Volvo can't even take care of it.
Old Mar 16, 2011 | 01:29 PM
Did you do a search here? Usually front end parts on a fwd car wear out and cause shaking. Hard to believe the Volvo stealer couldn't fix it, was that a dealer?
https://volvoforums.com/forum/showth...=front+shaking
Old Mar 18, 2011 | 09:05 AM
jojoswhip's Avatar
Hello,
I had the same exact issue when i owned my S40. My vibrating was getting worse as time passes and it was only as I was accelerating on not when the car was at cruising speeds. It turned out to be my passenger axle but I would definetely check your axles before throwing money into the car. Let us know the outcome.
jimduke
Jun 23, 2012 12:13 PM
Volvo_n00b
Feb 26, 2011 01:08 PM
junkmorning
Jul 28, 2006 12:22 AM
igtc
Jun 16, 2006 01:43 PM
ghostriderT6
May 4, 2006 04:15 PM
