Bad Power Steering Rack or Pump?
Old Oct 22, 2007 | 07:59 PM
Flip's Avatar
Default Bad Power Steering Rack or Pump?
Hi all, I recently had a post about some groaning noises when making a left turn which turned out to be my power steering fluid resevoir being low. Well I topped it off since but now I noticed that I have a leak. It started small where I would top it off once a week and now its pretty bad where I have to top it off almost everytime I drive the car. So, my question is, would it be the power steering rack or the pump that might be leaking and how can I tell. I'm not sure where the pump is located. I know if its the rack I need to replace the whole assembly which I read in a previous thread. So if anyone can give me some insight on this problem I would greatly appreciate it. Thanks in advance!
Old Oct 22, 2007 | 09:16 PM
Default RE: Bad Power Steering Rack or Pump?
The pump is up top above the alternator.
You will have to fill it up and run the car watching for it to leak.
Might just be a little hose that is bad.
Old Oct 22, 2007 | 09:53 PM
Flip's Avatar
Hi Tech,
So would it be very obvious if it was the pump or hose, as in the fluid would be dripping from engine bay instead of near the PS rack, I would assume? When I look down from under the hood near the firewall I can see the PS rack and its definitely wet from the PS fluid. The drips are more to the right side of the car, almost underneath or just before the front passenger seat. I would also like to know if the PS goes out completely how dangerous would that be while driving? Thanks.
Old Oct 22, 2007 | 10:22 PM
If the hose from the fluid bottle was leaking it might drip on the passenger side where you see it leaking from.
Is it all wet by the bottle?
Are the hoses from the bottle all wet?
It will be very hard to steer if you run all the way out of fluid.
Old Oct 22, 2007 | 10:43 PM
Volvocars's Avatar
Don't condem the expensive parts before checking the cheap ones.
Old Oct 23, 2007 | 05:23 PM
Flip's Avatar
No, the hoses aren't wet at all neither is the pump. The only area that seems wet is where the PS rack is on the passenger side.
Old Oct 23, 2007 | 05:24 PM
Clean it all up nice and if you can put the car on ramps then let it run and watch for it to leak.
Old Oct 23, 2007 | 08:47 PM
Flip's Avatar
OK, I'll keep you posted. Thanks!
Old Oct 23, 2007 | 09:33 PM
samadkins29's Avatar
Just take it to a shop and have them look at the rack and tell you if is leaking. If it is, then go to the closest junk yard and pick up one that isnt. I just had to to this job and the total was around $450 for parts an labor on a used one. New it would have been a $1000 job.
Old Oct 23, 2007 | 10:40 PM
Flip's Avatar
Yeah I know I should but I always feel like when I take my car to the shop they always get me for something else, what can I say I'm a sucker when it comes to car shops. Thats why I've been trying to learn to do things on my own whenever possible and if its too much for me to handle then I'll certainly take in. By the way, I found a shop online that sells a new PS rack for $350. www.carsteering.com. Just need to find a shop to put it.
Thanks for your input!
Old Oct 24, 2007 | 12:46 AM
Volvocars's Avatar
Well if you have checked those hoses. And it only looks like it is coming from the r/f(=if you were sitting inthe drivers seat)boot (=black plastic accordian). Then itmay be your rack.
The only way to ever really learn anything is to do it your-self. However this is a big job for a novice and I don't recommend it. For several reasons.
Used partsare agamble. Its been my experience that they almost always have a pay out.
As for a finding a good shop.
Some tips
Ask to speak to the tech working on your car.
Ask him to show you whats wrong.
Ask him thewhyand how.
You may not understand every technical aspect but I'm sureyou know when your getting snowed. Especially when youvisually can observe what they are talking about.
If they won't do this; be suspect.
Old Oct 24, 2007 | 03:15 PM
Flip's Avatar
Well, after further inspection I did notice that it was coming from that boot on the right hand side which would mean that its a bad rack. I did call around for some pricing and boy, its not cheap. The Volvo dealer by me said it would cost around $1,133 for the whole job. $270 for installation only if I bring in my own part but without a warranty. So $350 for a new rack online plus $270 for install sure sounds better than $1,133. Either way its gonna cost me a pretty penny. Thanks for your help!
timmins
Sep 28, 2022 02:00 PM
tr_car_nut
Sep 27, 2011 08:54 PM
schwalbe181
Aug 2, 2010 04:13 PM
blckrob042000
Jan 31, 2010 06:28 PM
katiejoyful
Dec 12, 2007 04:49 PM
