Can the fuel door be opened manually?
Old Dec 19, 2009 | 09:58 AM
starlingbirds's Avatar
Default Can the fuel door be opened manually?
I am replacing the motor for the driver power window in my 2000 s70 and have unhooked all the electrical plugs in the door realizing I cannot now open the fuel door. I have tried hooking that particular plug up again and it still will not open, although the trunk opens just fine. Any suggestions before we run out of gas?
Last edited by starlingbirds; Dec 19, 2009 at 09:59 AM. Reason: left out model of car
Old Dec 19, 2009 | 10:43 AM
mkc70's Avatar
Should have a manual release cable in the trunk. Might not be readily visible but on the side with the fuel door, good luck.
Old Dec 19, 2009 | 03:59 PM
THank you so much for the help. I could not find such a cable, though...If it has one, it is very much hidden. I ended up taking off the plastic latch and velcroing the fuel door closed ha! For now, I can get gas! When I finish the window, I will then try to fix the fuel door! Thanks again for the timely reply! Jeff
tbrentlong
Dec 20, 2013 01:27 AM
kirkf1835
Sep 28, 2013 08:43 AM
Mickeyj1966
Dec 18, 2011 03:36 AM
Dingbat
Jan 11, 2006 12:22 AM
