Factory Radio
Old Jan 9, 2009 | 04:43 PM
wvuboy0207's Avatar
Default Factory Radio
Hi all,
Sorry if this has been posted but I tried to look thru for the answer.
I recently purchased a 98 S70 and would like to replace the factory radio that has only a tape player with one that has a CD player.
If I get a factory radio that has a CD player will it hook up with the current connections I have for the radio with just a tape player?
Any help would be greatly appreciated.
Thanks!!
Adam
Old Jan 9, 2009 | 04:51 PM
Default RE: Factory Radio
Yes it will work. Make sure you get the radio code.
Im not sure about the 3 disk though you might need an amp to run that one.
Old Jan 9, 2009 | 04:56 PM
wvuboy0207's Avatar
Thanks for the quick reply!
Would you happen to know where to get any instructions on taking out an old factory radio and replacing it with a factory radio that has a CD player?
Also
The remotes don't work to unlock the cars and I was hoping to add a remote start? Is this something that could be done say by bestbuy?
Thanks
Adam
Old Jan 9, 2009 | 05:12 PM
For the radio if you look at the beginning and end of the preset buttons there is little tabs going up and down. Press them in and then pull them out. Then the radio will slide out.
For the remote start if it were me I owuld not go to Best Buy I would go to a radio shop only that knows what they are doing.
Old Jan 9, 2009 | 05:16 PM
wvuboy0207's Avatar
ok.
Once i pull the radio out are the connections in the back the same as the connections on the back for a factory radio with a cd player?
Thanks for all the help!
Old Jan 9, 2009 | 05:31 PM
Yes the same connectors.
Old Jan 9, 2009 | 05:32 PM
wvuboy0207's Avatar
OK awesome.
Thanks for all the help. I'll keep my eye out for a factory radio with a CD player.
Thanks again!!
Old Jan 9, 2009 | 05:58 PM
Your welcome.
Old Jan 11, 2009 | 09:00 AM
simul8guy's Avatar
What you're looking for is the SC-816. Checkout e-Bay, for example...
http://cgi.ebay.com/ebaymotors/Parts...parms=72%3A727|65%3A12|39%3A1|240%3A1318
or
http://cgi.ebay.com/ebaymotors/Parts-Accessories___VOLVO-S70-V70-S40-C70-850-CD-Radio-SC-816-97-98-99-2000_W0QQitemZ120359189196QQddnZPartsQ20Q26Q20Acce ssoriesQQddiZ2811QQcmdZViewItemQQptZCar_Audio_Vide o?hash=item120359189196&_trksid=p4506.c0.m245& amp;_trkparms=72%3A727|65%3A12|39%3A1|240%3A1318
or contact Erie Vovo (Volvo parts recycler) and see what they have (they can be a bit on the pricey side)
http://www.erievovo.com/search_resul...h&iLevel=1
As Tech noted, make sure you get the 4-digit security code from the seller or the radio will not work.
Old Jan 11, 2009 | 11:12 PM
crunch5868's Avatar
i have a 98 s70 but mine came with the cd player stereo. lmk if your still looking because i put in an aftermarket one so ill sell you the factory cd one your looking for if you want.
mstrplmber
Jul 23, 2008 02:00 AM
volksnut
Jun 8, 2007 05:01 PM
rgs4x
Mar 27, 2007 02:13 PM
ko_kidd
Sep 8, 2006 12:03 PM
