How much is my car worth?
Old Sep 28, 2010 | 03:39 PM
S70LE's Avatar
Default How much is my car worth?
I purchased a '98 S70 T5 Limited Edition in June. The car has 115,000 miles on it and is in good condition appearance wise. Black exterior/Black & Suede interior, w/center speaker on the dash (like the C70). Soon after buying the car I noticed a large puff of white smoke coming from the tailpipe only on the initial startup in the morning or after letting it sit for several hours. It does not blow out any smoke on acceleration. I had a new turbo installed w/an "R" manifold and it did not fix the problem. Now the dealer suspects it could be a head gasket. Since owning the car the following has been done:
Volvo 16T Turbo
Heater Core
Torque Mount
Right Motor Mount
Replaced stock grille w/Cross Country
Cam seals
Antenna
Iat Sensor/Thermostat
Air Cleaner air duct
I want to sell it....How much is it worth
Old Sep 28, 2010 | 07:23 PM
2004VolvoS60_Bilal's Avatar
Depends on the shape and if it needs any major work, which looks like it does. I think it's probably worth $1500-$2500. Have you tried trading it in?
Old Sep 28, 2010 | 09:25 PM
spaded09's Avatar
Yea $1500 to $3000 sounds right.
Old Sep 28, 2010 | 09:33 PM
NADA Guides says ave trade in is $3,050. With it smoking take anything above 2k. Has the PCV system been replaced lately?
Old Sep 28, 2010 | 09:43 PM
turbo matt's Avatar
Volvo 16T Turbo
Heater Core
Torque Mount
Right Motor Mount
Cam seals
Antenna
About $1,000 dollars; who do I need to make the check out too and where do you live?
Seriously though if it is running fine and no problems it is probably something simple. Any dash lights coming on. I would suspect turbo seals (if the 16T was used).
tomb69
Oct 29, 2014 01:36 PM
93-245
Jun 21, 2010 08:48 AM
aryanvahedi
Nov 18, 2009 08:59 PM
lombia
Feb 23, 2008 04:03 PM
V8SRSLO
May 24, 2007 08:26 AM
