Secondary air fan???
Old Jul 31, 2010 | 10:28 AM
dsixxer's Avatar
Exclamation Secondary air fan???
My engines pullin the code for a failure of the "secondary air fan"........
does anybody know where i can locate this fan and if i can just
clean it and put it back or if its a "when they fail, they fail" type of
thing...Thanx guys.
Old Jul 31, 2010 | 10:39 AM
Do you mean secondary air induction pump?
If so it is mounted under the car like right behind the front bumper.
On the front of the air box (air filter lid) there is a rubber hose that mounts to it. Follow that hose down to the pump. But usually the pumps go bad. They end up full of water and seize up.
Old Jul 31, 2010 | 11:33 AM
dsixxer's Avatar
yes i think thats it. i wonder if theyr expensive...it has something to
to with smog i think.
Old Jul 31, 2010 | 11:42 AM
Yes expensive!
Yes has to do with smog. It takes hot exhaust air and routes it back into the induction system. Like an EGR setup on older cars.
Old Jul 31, 2010 | 11:46 AM
dsixxer's Avatar
holy crap, upwards of $250? i just found one online. would it
be a terrible idea for me to get one off a low miled junk yard S70?
Old Jul 31, 2010 | 11:57 AM
You can try but they all suffer the same problems.
Old Jul 31, 2010 | 12:02 PM
dsixxer's Avatar
what would you do if it was your car? and will it harm my
vehicle if i drive it for awhile in this state?
Old Jul 31, 2010 | 12:10 PM
You can get away with it for a little while.
In FLA you can throw it away and get an ECU to bypass it.
That is what I would do.
But being in NJ and knowing how picky they are (used to live there) you will end up having to replace it.
Old Jul 31, 2010 | 12:48 PM
dsixxer's Avatar
as of August first, there will be no more inspection law in NJ. YAY!!
now about this ECU thing.....lol.....how would i go about doing this?
and will it make the check engine light go away?
Old Jul 31, 2010 | 04:13 PM
Some chip company's when they chip it they can remove the air pump from the entire system and yes it will keep the check engine light out.
Air Defender
Jul 21, 2011 12:23 AM
heybuddy
Mar 2, 2009 08:12 PM
jtvrba
Jan 1, 2008 02:20 PM
tom1568
Dec 21, 2005 09:36 PM
jrw
Nov 19, 2005 09:13 PM
