starter problem
Old Jan 19, 2014 | 12:47 PM
bemerman's Avatar
Default starter problem
Pete again, still adding symptoms to wierd S70 cutting out while going down the road when all I did was try to adj. power seat. The motor that engages the starter is turning over good but not engaging starter. Not sure why this might have made engine cut out, or do or did I have couple problems at same time. Thanks Pete
Old Jan 19, 2014 | 02:49 PM
kwatt's Avatar
You're saying you can hear the starter running but the engine is not turning over? if tha tis the case, replace the starter. The starter solenoid is not engaging.
Old Jan 19, 2014 | 04:41 PM
Do you have a CEL or any codes?
stecz
Jun 24, 2007 05:54 PM
brownnb
Jun 11, 2007 10:59 PM
brownnb
Jun 11, 2007 05:09 AM
echaikin
Sep 27, 2006 10:56 PM
kermitthefrog
Apr 17, 2005 08:01 PM
