Vibration problem
Old May 16, 2013 | 06:46 PM
SvtFoci's Avatar
Default Vibration problem
Hi all, new member, lurked for a while. I have a '99 S80 T6 90k, and recently noticed vibration in the front and through the steering wheel. It happens when I go over bigger bumps where the cars goes down after going over the bump/little hill, and when I turn right, turning left is all fine. I have go pretty fast and sharply into the curve for it to happen, and also over the hills i gotta go pretty fast. Normal turning is all fine, it's when I push it that it happens. I put new sway bar links on it today, so that's not it. Anybody know what it may be?
Old May 22, 2013 | 05:40 PM
SvtFoci's Avatar
Anybody? Also, it goes away after driving for about 5-10 minutes.
Old May 23, 2013 | 07:52 AM
akabond's Avatar
this looks like a very common problem and i have read a lot about this on this forum. why dont you do a search. I am sure you will get lot of similar problems with solutions
Old May 23, 2013 | 11:28 AM
SvtFoci's Avatar
Oh I tried that, I spent about an hour looking for something similar, on several different forums too. There was really nothing that I could find that would help me out.
Old May 23, 2013 | 07:31 PM
torontos80t62000's Avatar
WHEEL BARRING, BALL JOINT OR TIE ROD problems can u lift the car up on the problem side..???
Old May 23, 2013 | 09:17 PM
SvtFoci's Avatar
Yes I can. I tried the 6 and 12 o'clock wiggle and 9 and 3. No shaking or play at 6 and 12, there is just a little bit a 9 and 3, so not sure if that's something. It's weird cause it goes away after it "warms" up once I drive for about ten minutes.
Old May 23, 2013 | 09:58 PM
first start off simple put your full weight into the tire test you dont want any play a little play in the tie rod is fine but its hard for me or you determine how much is good then remove wheel, remove rotor, chec wheel hub for any giggle or wiggle you dont want any play not one bit or any visible worn parts in wheel hub .. second is the rotor warped? its suppose to be perfectly straight or evenly worn down from pads.I had a vibration in bra pedal when applied on the hi way..... every thing seemed fine to me did the same test you did then brought to shop mechanic lifted car up put his full weight(230lbs Mechanic) into a ferm bottom of tire wiggle test ..right away he said you need ball joints badly..dammmmmmmmmmmmmmm ps i replaced the sway bar lin was causing a clunc over small bumps after repair ..bolts wer not tight enough .......tightened bolts changed ball joints my self problem solved .............hard cornering puts weight on sway bar, ball joints and wheel barrings
the wiggle at 9 & 3 sounds very suspect
Strangebrewer
Dec 15, 2010 06:33 PM
mick1232
Apr 26, 2009 06:43 AM
laterno
Jan 19, 2009 07:54 PM
ocean238
Apr 17, 2008 06:20 PM
Macgregorguy
Dec 19, 2004 03:48 PM
