A/C compressor - replacing
Old Nov 10, 2010 | 05:53 PM
Daddy Z's Avatar
Default A/C compressor - replacing
My friend is convinced its bad. How hard is it to change if I want to do it in my driveway? I have very little experience with Volvo's and I dont have access to the car so see where its located. I assume it's removed from underneath? Is this an afternoon job?
Thanks
Adam
Old Nov 14, 2010 | 07:28 AM
It is kind of a pain due to a useless bracket volvo puts in there. You need to remove the PS pump and alternator to get to the compressor bolts.
Old Nov 23, 2010 | 08:46 AM
I8ASaleen's Avatar
Hard. You will need a set of crowfoot wrenches to even get some of the bolts out, and good luck getting them back in.
Old Mar 7, 2011 | 06:30 PM
mike1976's Avatar
i found that it was better to take it off from under the car then there are only 4 bolts take out the 2 bolts on the bottom of the alternator well as far as you can get them and the same on the bottom of the A/C compressor and drop it down take off the pipes and there you go should take about 20min
sorry this is how i did it on my s40 but hope it helps
98_V70_T5
Jun 8, 2014 03:38 PM
sghokie
Jul 25, 2011 05:00 AM
etype38
May 4, 2005 07:08 PM
RonNaismith
Feb 28, 2005 07:24 PM
