Rear brake caliper removal
Old May 11, 2025 | 05:06 PM
mlepesant's Avatar
Default Rear brake caliper removal
Hello,
I am working on the daughter's 2004 V40 and am trying to replace the rear pads. After I remove the 2 caliper bolts am I supposed to be able to slide the caliper out? I cannot. I have used a hammer but am afraid I forgot something. I have worked on several cars before and never had any issue removing calipers.
Do I need to loosen the handbrake cable or do something else?
I have watched a video of a guy who is able to easily remove the calipers right after removing the 2 bolts.
Thank you.
Old May 11, 2025 | 11:50 PM
You have to manually retract the caliper pistons. The e brake ratchets them out. That's done by spinning the caliper pistons back in with a special tool.
Old May 12, 2025 | 12:23 AM
mlepesant's Avatar
Thank you. But i can’t even have access to the piston. I cannot slide the caliper out. How would i slide back the piston in? Really sorry if i don’t understand.
Old May 19, 2025 | 06:01 PM
sometimes the rotors wear to the point a ridge develops and the caliper wont slide off as the pads get hung up on the ridge. For the general procedure you should be able to find a Youtube vid that shows how to remove the caliper to access the pads and use the brake retraction tool. If you do in fact have a ridge on the rotor, you can grind it off since the rotor is toast and needs to be replaced.
Old May 19, 2025 | 06:35 PM
mlepesant's Avatar
Thank you. I am going to attempt again next weekend. I have watched several vids and removing the caliper is always super easy so mine are probably stuck.
Old May 20, 2025 | 06:36 PM
don't be shy about using some leverage to get it unstuck. :-)
turbazo2001
Apr 5, 2023 01:15 PM
vikiius
Feb 17, 2014 07:59 AM
tenui
Dec 26, 2013 08:20 PM
ddub
Apr 15, 2009 10:34 AM
dannydoo
May 12, 2008 08:11 PM
