Oil leak help ! Volvo v70 2.4 non turbo
Old Aug 31, 2013 | 04:15 PM
Chucky101's Avatar
Default Oil leak help ! Volvo v70 2.4 non turbo
Recently bought a v70 2001 2.4 non turbo got her home noticed oil pressure warning looked underneath and found all the engine oil leaking out. Did a bit of investigation found Pcv completely clogged removed and replaced removed sump and cleaned channel that connects to PVC changed oil filter and dip stick gasket run her up today and started to drip oil again not too much just one or two drops. Could I have blown the crank seal due to Pcv failure ? The oil seems to be coming from around the bottom of the timing belt
Old Aug 31, 2013 | 07:49 PM
VTBricked's Avatar
The rear seal is more commonly the one to fail due to overpressure. Pull the cover to isolate the leak source. If it was a turbo, I'd say it was the oil cooler thermostat housing, but yous is N/A.
danielarroyo0001
1998-2000 model year V70
Nov 3, 2014 11:26 PM
Ablorx
Jul 4, 2014 08:33 PM
Amopower
Jan 4, 2011 10:34 PM
trevy
Sep 20, 2010 11:56 AM
snsrgy611
Apr 10, 2009 11:31 PM
