Error Code P0016
Old Apr 1, 2024 | 01:29 PM
dee0007's Avatar
Default Error Code P0016
Can someone help me diagnose this problem? on a 2016 XC60 2.5T. Getting this code (P0016 - Crankshaft position camshaft Position Correlation Bank 1 Sensor A) constantly and loss of power. Recently got an oil change.
What could be the issue and what should i start with first? Cleaning the VVT solenoid? is there more than one? how do I know if one is faulty? Changing spark plugs?
Old Apr 1, 2024 | 02:03 PM
https://www.matthewsvolvosite.com/fo...ic.php?t=84993
check out this post for some good insights. The P0016 points to your exhaust cam's vvt. definately not a sparkplug issue. Could be wiring, could be the VVT hub, could be the solenoid sticking. How many miles on the car? When was the last timing belt service done?
Old Apr 1, 2024 | 02:42 PM
dee0007's Avatar
150k km = 93k miles. I just had this car for a year. Not sure if he timing belt was done at all? what is the VVT hub?
Old Today | 12:23 AM
Sinclair5's Avatar
What could be the issue and what should i start with first? Cleaning the VVT solenoid çin takvimi? is there more than one? how do I know if one is faulty? Changing spark plugs?
In simple terms, the engine control module (ECM) has detected that the timing of the crankshaft and camshaft is out of sync.
RAC1
Nov 23, 2022 07:57 PM
plcoomer
Mar 19, 2022 03:02 PM
xerxes66
May 12, 2017 03:25 PM
joe maroon 850
Mar 28, 2011 05:40 PM
gordon368
Sep 9, 2009 08:42 AM
