how to eject ecm?
Old Feb 15, 2009 | 12:44 PM
mrscullini's Avatar
Default how to eject ecm?
2000 v70xc
according to vadis, a special tool is required to remove the ecm. is there a way to do it without the tool? i have the housing cover and housing removed. there appears to be a pink slide lock but i cannot move it. i do not want to force anything.
Old Feb 15, 2009 | 02:15 PM
You have to slide both of the pink things on each side the same. You can slide one side a little then do the other till it is all loose.
Old Feb 15, 2009 | 02:19 PM
mrscullini's Avatar
thanks tech. do they slide to the rear of the car?
Old Feb 15, 2009 | 02:21 PM
I believe they do.
Old Feb 15, 2009 | 04:08 PM
S70driver's Avatar
TECH is correct, I did this not to long ago. It is a pain to do it this way but it works.
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
chris10wd
Nov 30, 2012 02:58 PM
sblaine
Feb 9, 2009 12:07 PM
Barnaclebill
Jan 8, 2009 12:32 PM
