Coolant pipes keep bursting
Old Jun 19, 2020 | 02:52 PM
Damian7437's Avatar
Default Coolant pipes keep bursting
Hi all
So over the last few weeks I have had to replace my top Rad pipe my egr pipe and now my filler pipe on my 2005 xc90. Has anyone experienced this at all as I'm hoping it's just the pipes are old and just needed replacing.
Old Jun 19, 2020 | 03:42 PM
If you are concerned about your cooling system, you can have the cooling system's pressure measured to test if you have a head gasket issue. The overflow cap is also a pressure release so make sure you have the correct cap for your model. As to having to replace a top hose, an EGR pipe and a filler pipe (meaning to the gas tank?), they have nothing in common other than being 15 years old :-) I've had to do similar maintenance work on my cars as well.
Old Jun 19, 2020 | 05:55 PM
Damian7437's Avatar
Thank you for that. That has gave me a bit of peace. Ibhave it booked in for a pressure test on thursday so fingers crossed
MrBoston96
Jun 9, 2016 01:37 PM
Andrew Fritz
Jan 11, 2016 05:38 PM
frustrator-bolt
Aug 12, 2009 09:21 PM
m2point1
May 30, 2008 06:02 PM
RedBrick
Jan 7, 2006 10:33 AM
