Cracking Front End Mystery Help!!!
Old Oct 27, 2014 | 07:06 PM
Campanones's Avatar
Default Cracking Front End Mystery Help!!!
Hi guys hoping you can help with the mystery. My wife and I have owned an xc90 2007 for almost 6 years. Bought used ( lease return) and every since we got it, I noticed a cracking noise when braking at a stop sign or accelerating. The main components of the front end have been replaced once or twice. Lower control arms, axles ( under warranty) some special bolts that stretched but nothing works. I now have the pleasure of driving the vehicle daily and it is driving me nuts not knowing. I hate to take it back to the mechanic because I always get suckered into replacing something in the hopes it will fix the issue. I was just reading about lubricating the axle splines??? Is that it? Any suggestions? Any good mechanics in Miami?
Old Oct 27, 2014 | 08:26 PM
damien360's Avatar
Have the subframe bushings been replaced?
Old Oct 27, 2014 | 09:15 PM
ES6T's Avatar
Probably don't need to replace the subframe bushings, just lube them. There is also a bulletin for some plastic washers to install between the subframe and the car.
Old Oct 29, 2014 | 08:20 PM
Campanones's Avatar
Any particular way to lube them? What king of grease to use?
Old Oct 29, 2014 | 09:13 PM
ES6T's Avatar
Remove the bolt, clean and lube the washer and bushing. Install the plastic washer from the bulletin between the bushing and metal washer. Lube with white lithium grease or bearing grease... Whatever you have
artistnan
May 10, 2010 08:43 PM
hfs
Feb 25, 2009 02:37 PM
E99S80T6
Oct 13, 2008 01:27 PM
fpswhite
Apr 23, 2008 09:03 PM
bryanzamora78
Oct 6, 2006 09:37 PM
