Help with rear dvd
Old Jan 5, 2023 | 09:33 PM
  #41
photojames's Avatar
The fifth secret fuse box, found it! Awesome. I pulled the fuses and they were rusted and broken. Local shop guy was able to clean it up and replaced the fuses. We actually thought it didn't work but when I got home....The DVD power button was glowing, I pushed it, and voila, DVD player in action, screens turned on, greatness. Thank you. Now to local record shop that sells DVDs for $2 a pop. Daughter is going to love this.
Old Jan 4, 2025 | 09:52 AM
  #42
medusaint's Avatar
Originally Posted by Oralmaxfacial
Indeed. I had the same problem with RSE ..after extensive research I thought it was the DVD harness itself so I changed that and nothing .. There are three fuses as mentioned above however the culprit is found on the right rear side of the XC90. You must remove the triangle foam carpet on the bottom right side then remove the side panel. At the bottom there are two individual fuses and are covered each in its own capsule the closest one to the frame is the culprit . 10A fuse . This one is not in any diagram . As you see in the pic the green one is the 5A fuse and the left one is the 10A . Open the capsule fuse is underneath .
Im not quite sure why but I just cannot see where these two fuses are. I have a (new to me) 61 plate Executive with two screens in headrests. Have removed the triangular carpet and the side panel in the boot but there is no sign whatsoever of anything like the fuses you show. very wierd.
cborjon
Jun 27, 2021 07:23 AM
marveryl
May 29, 2013 03:15 AM
S70driver
Feb 24, 2008 10:59 PM
S70driver
Sep 30, 2006 06:56 PM
