Hood Release Routing
Old Jul 8, 2016 | 01:32 PM
shotgunsean76's Avatar
Default Hood Release Routing
A shop removed my hood release cable after being unable to get the hood open, in fact, they cut it....
I have replaced it on the mechanical side but am having issues finding where it goes through the firewall when looking under the dash.
Can anyone tell me where it goes through, or provide an image?
Old Jul 9, 2016 | 10:52 AM
VolvoTech65's Avatar
The cable runs along the left frame rail through a grommet under the brake booster and comes out near the A-pillar.
Old Jul 10, 2016 | 12:37 PM
Thanks,
The search continues.
I can't see it from outside the vehicle. Inside, I'm guessing the grommet is under the rubberized insulation.
I may post some pictures in a few to get some general direction.
Thanks,
Sean
Old Jul 10, 2016 | 02:29 PM
Sean,
I found a link that may help you out some. It's not an XC90 and on the third picture where they talk about removing the battery you will need to removed your air filter housing.
Everything else is generally the same as the XC90.
http://www.matthewsvolvosite.com/for...18571&start=10
Old Jul 10, 2016 | 03:09 PM
Thanks!,
I actually got it taken care of just minutes before your post.
On my XC90, the grommet location is directly to the right of the center of the brake booster. It is in a small cluster with two other cables or electrical lines but they are pretty obscured by the cowl drain.
Removing the cowl drain by taking the single 10mm plastic nut and then just pulling it out seemed to be the silver bullet here. As soon as it was out of the way, the grommet and hole where the cable runs was easy to see. with it in place, it was not visible at all.
Getting it routed on the interior was something else entirely. If anyone ever has to do that, do yourself a favor and have a small fish tape or stiff wire. Also remove enough zip strips and other things holding the rubberized insulation down so that it can be pulled away from the firewall easily.
I am once again able to easily open my hood for the first time in a year (without the use of (pliers).
Again, thanks a ton for your help VolvoTech65!
Old Jul 10, 2016 | 03:19 PM
Default Grommet location for the hood release cable on a 2007 XC90
Images for the grommet location.
MDUBBSS70
May 28, 2014 09:02 PM
BPATR1CK
1998-2000 model year V70
Aug 28, 2012 06:09 AM
montysano
Jul 21, 2007 09:24 AM
Lichty17
Oct 13, 2006 08:28 PM
dougsnow
Apr 22, 2006 07:07 PM
