Gear shift knob removal???
Old Sep 22, 2009 | 07:39 PM
solarman's Avatar
Angry Gear shift **** removal???
I want to replace the dried out and cracked gear shifter boot and have no idea how to remove it. At the bone yard I had to braek it off but upon inspection can find no easy way to R&R this part!
Old Sep 22, 2009 | 07:49 PM
The **** just pulls off.
Old Sep 22, 2009 | 08:16 PM
solarman's Avatar
I had tried that at the bone yard and it pulled off but would not re attach
Old Sep 22, 2009 | 08:36 PM
That is how I have changed all that I have.
We are still talking about just the **** correct?
Old Sep 23, 2009 | 07:37 AM
solarman's Avatar
The automatic transmission lever in the console is the lever/handle
Old Sep 23, 2009 | 06:58 PM
Are you wanting to remove the entire assembly after disconnecting the cable?
Old Sep 24, 2009 | 07:35 PM
solarman's Avatar
I just want to remove the handle assembly not the entire arm and linkage
Old Sep 24, 2009 | 07:57 PM
Which setup do you have?
Maybe the diagrams will help you.
Old Oct 15, 2009 | 07:22 PM
solarman's Avatar
Thanks alot I pulled real FN hard and she poped right off, then once I finished the new boot she poped right back on
Old Oct 15, 2009 | 08:10 PM
Glad all is good.
Old Sep 30, 2011 | 03:35 PM
Lulumike's Avatar
Wink Thanks
Thanks, Tech. it worked like a charm. I tried all the other methods on the Forums. So finally I said, OK, I'll pull it off and put both hands on it and knee on the seat, and yanked. And lo and behold, out it came.
Lulumike
Old Apr 1, 2013 | 01:57 PM
justincarner's Avatar
Im having the same problem. I literally pulled until i almost passed out and it didnt pop off. Any solutions?
Abathor
Aug 13, 2008 07:09 PM
chachouu
Dec 27, 2007 09:15 PM
nandrolone
Dec 16, 2007 08:58 PM
nandrolone
Jun 19, 2007 05:54 PM
