Gear shift knob removal???
Old 09-22-2009, 07:39 PM
solarman's Avatar
Angry Gear shift **** removal???
I want to replace the dried out and cracked gear shifter boot and have no idea how to remove it. At the bone yard I had to braek it off but upon inspection can find no easy way to R&R this part!
Old 09-22-2009, 07:49 PM
The **** just pulls off.
Old 09-22-2009, 08:16 PM
solarman's Avatar
I had tried that at the bone yard and it pulled off but would not re attach
Old 09-22-2009, 08:36 PM
That is how I have changed all that I have.
We are still talking about just the **** correct?
Old 09-23-2009, 07:37 AM
solarman's Avatar
The automatic transmission lever in the console is the lever/handle
Old 09-23-2009, 06:58 PM
Are you wanting to remove the entire assembly after disconnecting the cable?
Old 09-24-2009, 07:35 PM
solarman's Avatar
I just want to remove the handle assembly not the entire arm and linkage
Old 09-24-2009, 07:57 PM
Which setup do you have?
Maybe the diagrams will help you.
Old 10-15-2009, 07:22 PM
solarman's Avatar
Thanks alot I pulled real FN hard and she poped right off, then once I finished the new boot she poped right back on
Old 10-15-2009, 08:10 PM
Glad all is good.
Old 09-30-2011, 03:35 PM
Lulumike's Avatar
Wink Thanks
Thanks, Tech. it worked like a charm. I tried all the other methods on the Forums. So finally I said, OK, I'll pull it off and put both hands on it and knee on the seat, and yanked. And lo and behold, out it came.
Lulumike
Old 04-01-2013, 01:57 PM
justincarner's Avatar
Im having the same problem. I literally pulled until i almost passed out and it didnt pop off. Any solutions?
Abathor
08-13-2008 07:09 PM
chachouu
12-27-2007 09:15 PM
nandrolone
12-16-2007 08:58 PM
nandrolone
06-19-2007 05:54 PM
Quick Reply: Gear shift knob removal???
